1. Fatman0's Avatar
    My Htc One X drops it battery very quickly please help! The previous owner said the battery was just replaced!
    10-17-2014 03:49 PM
  2. Golfdriver97's Avatar
    The battery has probably gone bad and can't hold its charge. Can it be replaced?
    Sent from an AOSP M8
    10-17-2014 05:00 PM
  3. Fatman0's Avatar
    It was just replaced by previous owner...I have like 10h of battery....
    10-18-2014 12:49 AM
  4. Golfdriver97's Avatar
    Can you post screenshots of your battery use?
    10-18-2014 09:07 AM
  5. anon(55900)'s Avatar
    Maybe they lied, or you are running intense apps, go to apps and see what's running, you don't say how quick is quick, During the day, I set phone Airplane mode until break time.
    10-18-2014 02:28 PM
  6. Rukbat's Avatar
    It really depends on battery use, as Golfdriver said. Post both screens of battery use. (Press the graph at the top of the first one to get the second one.) If you need more use out of the battery than it can supply (constant use of a phone won't give you anywhere near 8 hours) you can get large external batteries that plug into the microUSB port, or you can buy a spare battery or two, with a charger than can charge both the phone and a battery not in the phone, and switch batteries during the day.
    (BTW, if you're constantly draining the battery all the way down, you're killing it. As a general rule [you don't have to be obsessive about it], the phone should be recharged when it gets down to 40%-60% of charge. Discharging it much less than that regularly shortens its life. See Battery University - How to Prolong Lithium-based Batteries)
    10-18-2014 03:33 PM
  1. Moto X 2014 What happened to Moto voice???
    By DrewGross in forum Moto X (2014)
    Last Post: 11-05-2014, 09:31 AM
  2. Is it harmful to charge a smartphone while it is on?
    By baghro in forum Ask a Question
    Last Post: 10-28-2014, 04:35 AM
  3. Is Moto X 2nd Gen a good choice to replace my RAZR M?
    By pdarrah in forum Moto X (2014)
    Last Post: 10-20-2014, 03:21 PM
  4. Replies: 3
    Last Post: 10-17-2014, 10:22 PM
  5. New iPad Air 2 and unlocked Nexus 5 - what SIM do I use?
    By Strategerizer in forum Ask a Question
    Last Post: 10-17-2014, 04:04 PM
