1. Saumyadip Sarkar's Avatar
    My nexus 7 2013 is shutting down at 10% to 13% battery level after kitkat 4.4.4 update. It would start only after I connect it with the charger. How do I overcome the problem?
    10-18-2014 04:53 AM
  2. belodion's Avatar
    Welcome to AC☺.
    Try a Cache Partition wipe, good practice after an update.
    http://support.t-mobile.com/docs/DOC-7405
    Consider also the possibility that the update and the battery trouble may be no more than coincidental, and that the battery may simply be failing.
    Golfdriver97 likes this.
    10-18-2014 07:24 AM
  3. Rukbat's Avatar
    You shouldn't run the battery down that low if you want maximum battery life (see Battery University - How to Prolong Lithium-based Batteries). The maximum battery life charge point is 40%-60%. Continually discharging to 10% will give you about 18-24 months (as opposed to a few years - two of mine from 2004 are still working fine).
    belodion likes this.
    10-18-2014 09:23 AM
  4. Golfdriver97's Avatar
    I agree with the cache partition wipe.
    [GUIDE] Nexus 7 (2012 & 2013) Cache Partition Wipe
    10-18-2014 09:29 AM
  1. Xperia Z3 uses a lot of battery
    By Henrikdk93 in forum Sony Xperia Z3
    Last Post: 10-20-2014, 02:37 PM
  2. Why isn't my data working after I did a root?
    By nixiedo in forum Samsung Galaxy S3
    Last Post: 10-18-2014, 10:06 PM
  3. Replies: 1
    Last Post: 10-18-2014, 09:25 AM
  4. How do I unbrick a LG G2 D802?
    By Averine in forum Ask a Question
    Last Post: 10-18-2014, 09:01 AM
  5. Sensors using too much battery?
    By classic20 in forum HTC One X
    Last Post: 10-18-2014, 02:12 AM
