1. Chris Johnson21's Avatar
    Everything is fine when using bluetooth, it will play music and the media from navigation. Sometimes though I'd rather be listening to the radio(FM).
    I certainly don't want to have to turn bluetooth on and off all the time to get audio for nav. Hoping there's an app or setting I'm missing.
    I'd take either fix. Have my phone only stream music, and not stream navigation. Or find a way to get navigation voice to interrupt FM.
    Thanks!
    10-23-2014 11:22 AM
  2. cbryancan's Avatar
    You'd have to combine the audio streams from the phone and the radio, and I don't know of an easy way to do that.
    What about using a radio streaming app on your phone? If your station is available on iheartradio or tunein, then you could get radio that way and still have voice prompts.
    10-23-2014 01:30 PM
  3. Rukbat's Avatar
    cbryancan's way will work. If you want the actual radio, and the nav from the phone, you'll need car audio that interrupts the radio when sound comes through the Bluetooth. Talk to your car dealer or a local car audio store.
    10-23-2014 03:13 PM
  1. how to get ready for android L OTA?
    By ljxdaly in forum Google Nexus 7 (2012) Rooting, ROMs, & Hacks
    Last Post: 11-08-2014, 05:56 AM
  2. Replies: 9
    Last Post: 10-24-2014, 08:40 PM
  3. Replies: 4
    Last Post: 10-24-2014, 01:17 AM
  4. After I do a root can I restore the default system back?
    By Mido Enab in forum Ask a Question
    Last Post: 10-23-2014, 08:37 PM
