1. 700077k's Avatar
    I have a samsung galaxy s blaze and recently it has been randomly turning off and then it will start vibrating every 2 to 3 seconds. I will eventually then be able to turn it back on but then it will do this again. I have taken the battery out multiple times and have left it out for almost an hour but that didn't help. I also have already done a factory reset and that did not help. What should I do next to make this stop happening.
    10-28-2014 09:43 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! The next step would be to try a new battery.
    10-28-2014 10:22 PM
  3. Rukbat's Avatar
    You didn't mention whether the phone ever got wet - even slightly, like by being used in a heavy rain. Water in the phone, even if it's dried right away, could cause those symptoms.
    10-28-2014 11:39 PM
  1. Replies: 15
    Last Post: 02-10-2015, 01:25 PM
  2. Should I Dump the Nokia Icon for a Galaxy S5?
    By msdugn in forum Samsung Galaxy S5
    Last Post: 10-30-2014, 01:40 PM
  3. Rooted Tab S 8.4 to fully use external storage?
    By Aredubu in forum Samsung Galaxy Tab S 8.4
    Last Post: 10-29-2014, 10:24 AM
