1. AC Question's Avatar
    working battery, Shows 0%
    10-30-2014 06:27 PM
  2. belodion's Avatar
    Assuming that there is a working power supply at the wall socket, then one or more of the following is at fault: the plug from the charger into the wall socket; the charger; the USB lead; the USB port in the phone; the battery; or something deeper inside the phone. You'll have to eliminate them one at a time.
    10-30-2014 07:17 PM
  3. vannylugo's Avatar
    Are the contacs the same?
    10-30-2014 07:30 PM
  4. Rukbat's Avatar
    Evidently the calibration is off. Let the phone run until the phone tells you to plug in the charger. Turn the phone off, plug in the charger and let it charge overnight. Turn the phone oon and you should see a 100% charge level. If not, repeat once more. If that doesn't fix it, whether paying to get it fixed depends on 1) whether it bothers you (it should) and 2, what the phone is worth. It may cost more to fix it than to replace it.
    10-30-2014 11:29 PM
  1. Why is At&t charging more for the Note 4 than the other carriers?
    By scottf0624 in forum Samsung Galaxy Note 4
    Last Post: 10-31-2014, 09:06 PM
  2. Replies: 3
    Last Post: 10-31-2014, 12:02 AM
  3. Why is my AFGA photo tablet battery draining so quickly?
    Last Post: 10-30-2014, 11:52 PM
  4. Will USA charger work in 220v countries?
    By Aserar in forum Batteries
    Last Post: 10-30-2014, 05:47 PM
