1. AC Question's Avatar
    Hello guys,
    Yesterday I shut my cellphone down and let it charge for 2 and a half hours. When I come back it just doesn't turn on and if I try to charge it, no Icon seems to appear. I have tried a lot of things, even plug it in my computer but the Icon still not appear but my computer can detect that there is a device but it can't find a driver for it. I've also tried to turn it on with the Volume and Power(all combinations possible) but it didn't work. The cellphone wasn't rooted. Sorry if you couldn't understand me... I am not a native speaker.
    Thank you!
    10-31-2014 03:01 PM
  2. belodion's Avatar
    If it will not charge via the mains charger, or via your PC, it may be a failed battery, or perhaps the USB port in the phone. There are other possibilities, such as a problem with the power button or its associated circuitry, but I would get the battery tested first.
    (Your English is excellent.)
    10-31-2014 03:25 PM
  3. symtaxiz's Avatar
    Thank youu!!
    But I think that the problem isn't the battery itself because before it died it was 30%. Can I fix this problem if it is internal?
    10-31-2014 03:34 PM
  4. belodion's Avatar
    Welcome as a new member.☺
    You could well be right that the battery is not faulty, but it seems to me at least possible that it failed completely when you charged it. It could have failed in such a way that, even though it contains some electrical charge, it is unable to pass that charge to the phone. Or of course it could be some other type of fault, such as with the power button or some internal component.
    Have you tried pressing the power button for a long time, such as one minute, to try to switch the phone on? That will sometimes work.
    Although the battery in the Nexus 5 is not easy to remove, you could perhaps remove the back to make sure that the battery is making a good electrical contact, if you feel competent to do so.
    This may help:
    http://www.androidpit.com/how-to-man...exus-5-battery
    It may also be worth seeking further help in the Google Branded Android Devices & Accessories > Google Nexus 5 forum, whose members may be familiar with the problem.
    10-31-2014 05:33 PM
  5. symtaxiz's Avatar
    Thank youuuu!!! I think I am capable to remove the battery.
    Thank you so much, I am also going to ask in the Nexus Forum.
    belodion likes this.
    10-31-2014 05:51 PM
  1. Replies: 6
    Last Post: 11-05-2014, 03:17 PM
  2. Nexus 5 Battery calibration
    By michty_me in forum Google Nexus 5
    Last Post: 11-02-2014, 11:19 AM
  3. Replies: 7
    Last Post: 11-01-2014, 03:53 PM
  4. How do I increase the font size on my Android cell phone?
    Last Post: 11-01-2014, 04:40 AM
  5. Replies: 2
    Last Post: 10-31-2014, 03:29 PM
