I don't believe the Neo has the pads needed for the receiver, but you can buy a universal Qi receiver and solder it into the phone. (If you have any questions about how to do that, I suggest that either you don't, or you find someone to do it for you who doesn't. You can very easily turn the phone into a box of useless electronics.)
In addition, you'd need a Qi charging pad. (Wireless charging is pretty much a standard - any Qi receiver will work with any Qi pad.)
