1. apizz's Avatar
    I have Sony Xperia SL with me for about a year now. It was okay until few days ago. The phone battery suddenly drains faster than it should be. I figured this might be temporary so i turn the phone off whenever i am not using it. But something weird happened, the phone battery continue to drain even when the power is completely off. Before i went to bed last night, it was at 53% power, so i turned it off. Few hours later i tried switching it on again, only to find the battery level had dropped to 17%. This is completely abnormal..is there any way to solve this?
    11-04-2014 12:14 AM
  2. B. Diddy's Avatar
    It sounds like the battery might be dying. I believe your battery is not meant to be user-removable, so you'd probably have to bring it to a Sony service center or a local repair shop to get a replacement battery. You might find some do-it-yourself videos on YouTube, if you're handy.
    11-04-2014 12:45 AM
  1. What is the good case for this phone
    By Scaner in forum Sony Xperia Z3
    Last Post: 07-30-2016, 11:25 AM
  2. Cell phone standby?
    By LJL2MD in forum Motorola Droid Turbo
    Last Post: 11-04-2014, 01:27 PM
  3. Can I use my phone to make a quest at acmemb?
    By jemerysmith in forum Ask a Question
    Last Post: 11-04-2014, 01:02 AM
  4. Why is my Battery Draining so Fast you say?
    Last Post: 11-04-2014, 12:58 AM
  5. Replies: 1
    Last Post: 11-04-2014, 12:55 AM
