1. AC Question's Avatar
    If I buy a Nexus 6 in America will it work in Europe?
    11-04-2014 08:08 AM
  2. Rukbat's Avatar
    These are the frequencies the phone will handle:
    2G Network GSM 850 / 900 / 1800 / 1900 - all models
    CDMA 800 / 1900 - XT1103
    3G Network HSDPA 800 / 850 / 900 / 1700 / 1800 / 1900 / 2100 - XT1100
    HSDPA 850 / 900 / 1700 / 1900 / 2100 - XT1103
    4G Network LTE 700 / 800 / 850 / 900 / 1800 / 2100 / 2600 TD-LTE 2500 - XT1100
    (Bands 1, 3, 5, 7, 8, 9, 19, 20, 28, 41)
    LTE 700 / 850 / 1700 / 1800 / 1900 / 2100 / 2600 TD-LTE 2500 - XT1103
    (Bands 2, 3, 4, 5, 7, 12, 13, 17, 25, 26, 29, 41)
    Check the carriers you're going to use to find out if either model will handle all the frequencies they all need.
    11-04-2014 08:23 AM
  3. Golfdriver97's Avatar
    If you get it from the Play Store, most likely. It will already be unlocked, and compatible on most GSM carriers.
    11-04-2014 08:24 AM
  1. Replies: 11
    Last Post: 11-06-2014, 02:33 PM
  2. Replies: 1
    Last Post: 11-04-2014, 01:18 PM
  3. How do I turn off the lock screen on my Samsung Note 3 Neo?
    Last Post: 11-04-2014, 11:49 AM
  4. Can I do a Video Hangout between a Nexus 4 and a Nexus 10?
    Last Post: 11-04-2014, 07:30 AM
