Android 4.4.2. Location setting will not stay in (Power Saving Mode) . If activated it switches on the GPS, which is normally used for (High Accuracy Mode) . This is the only setting that works on my Note 3. The moment I put it in (Power Saving Mode) location settings switches off.
It's strange as I have always used the (Power Saving Mode), which uses data to get location. What am I doing wrong? I don't want the GPS, which uses a lot of battery.
