1. AC Question's Avatar
    my battery won't charge, because the phone turns on,displays the charging animation for 2 seconds and then switches off and turns back on again. there is not enough power to load the charging animation.and it won't charge without animation.what can i do to charge the battery?(my phone is a samsung galaxy note, slim kat rom, rooted)
    thank you
    11-07-2014 09:18 AM
  2. Rukbat's Avatar
    The Note is a 3 year old phone. Unless you've taken particularly good care of the battery (conditioned it before use, never discharge it more than 60%, never let it get warmer than you'd be comfortable being), it's way past the end of its life. Replace it. A good replacement is only about $10 (check on Amazon).
    11-07-2014 11:39 AM
  1. How do I move a txt msg to my PC?
    Last Post: 11-07-2014, 01:08 PM
  2. Replies: 1
    Last Post: 11-07-2014, 11:38 AM
  3. Replies: 0
    Last Post: 11-07-2014, 08:56 AM
