1. MishMomo's Avatar
    I have a samsung galaxy note 8.0 tablet and i just got it back from having the screen fixed from a local store here with great reviews.
    But when i plug it into the wall charger,it doesnt seem like it charges,i used to be able to use it and it'd charge within a few hours but now it doesnt seem to be moving at all.
    It's been almost a whole day and it went from 38% to 41% and when i tried using it it went to 24%. i read and people said it's the battery or the cable/usb charger.
    i already spent so much repairing the glass screen,is this a quick fix or a major cost?
    i only sent it in to be fixed cause it looked ugly and i like it perfect when i draw,the lcd and touch screen worked fine.
    the repair store wouldnt have broken it any way right?when i got it back it was still charged.where it plugs into the wall charger it is extremely hot.
    11-07-2014 05:46 PM
  2. Smply_Rcklss's Avatar
    Had a similar problem, I replaced the adapter & turned the device off. If that doesn't work, I'd suggest resetting.
    Tapatalk'n On The M8 ☕🐸
    11-07-2014 07:43 PM
  1. Android System and Battery Life
    By psyberjay in forum Samsung Galaxy Note 4
    Last Post: 11-08-2014, 08:37 PM
  2. Why won't my Sumsung Galaxy S4 turn on?
    By Rachel Keys in forum Samsung Galaxy S4
    Last Post: 11-08-2014, 08:35 PM
  3. What size band is your watch?
    By Sammuel1973 in forum Samsung Gear S
    Last Post: 11-08-2014, 08:26 AM
  4. What's is your most used feature?
    By gdhampton7 in forum Samsung Galaxy Note 4
    Last Post: 11-08-2014, 06:22 AM
  5. itunes music to my note 4 help
    By rob6070 in forum Samsung Galaxy Note 4
    Last Post: 11-07-2014, 11:34 PM
