1. AC Question's Avatar
    It happens whenever i lock the mobile and open it after 10 or more minutes
    11-08-2014 03:57 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Try booting into Safe Mode, which prevents 3rd party apps from starting up initially. Use it that way for a while, and see if that problem recurs. If not, then start opening apps one by one, and see if or when the problem recurs.
    On most Android devices, you can get into Safe Mode by pressing and holding Power until the Power menu appears, then press and hold Power Off until the Safe Mode prompt appears. Tap OK.
    11-08-2014 07:17 PM
  1. how much you getting out of your battery on average
    By currentdroiduser in forum Samsung Galaxy Note 4
    Last Post: 11-09-2014, 03:52 AM
  2. Why can't I reset my Android box to factory settings?
    Last Post: 11-08-2014, 07:31 PM
  3. My HTC M8 power button is not working
    Last Post: 11-08-2014, 07:29 PM
  4. why want my note 4 play my music?
    Last Post: 11-08-2014, 07:20 PM
  5. S3 Mini keeps Retarting while mobile internet data is on ?
    By jyothujinadevan in forum Ask a Question
    Last Post: 11-08-2014, 05:35 AM
