1. Tatt2014's Avatar
    I was wondering if the charger i have for my old galaxy s4 will work for my new Note 4 ?Iwant to make sure is won't damage my new phone.Thank you in advance
    11-10-2014 02:13 PM
  2. Rukbat's Avatar
    Damage? No. It may take longer for a given charge than the Note 4 charger does. Look at the output rating. It's around 5 Volts for both, but if the Amps (or mA) is too low for the S4, it'll take longer. The Note 4 should be able to draw 1.2A (or 1,200mA) during charge if it's available. If it's not (say the S3 charger can only supply 1A), the Note 4 will draw that amount until the battery is charged. (For instance, charging on USB is limited to about 900mA, but the phone charges nicely - it just takes longer.) It's been a LONG time since phone chargers put out anything other than 5.0-5.2 Volts, which is what matters. (And some of the old ones put out 4 Volts or 3.6 Volts, which wouldn't damage the phone, it just wouldn't charge the battery.)
    Tatt2014 likes this.
    11-10-2014 05:04 PM
  1. Why does my Note 3 randomly play music?
    By Carrie Greicar in forum Samsung Galaxy Note 3
    Last Post: 01-02-2017, 01:05 AM
  2. Replies: 35
    Last Post: 12-08-2014, 10:50 AM
  3. Why isnt' my S4 Mini connecting to 4G?
    By Carrie Greicar in forum Ask a Question
    Last Post: 11-11-2014, 12:19 PM
  4. Can I edit documents directly on the network with Android?
    By capaxdoli in forum Ask a Question
    Last Post: 11-10-2014, 07:57 PM
  5. What is wrong with my texting on my Galaxy S5?
    By vdupont13 in forum Ask a Question
    Last Post: 11-10-2014, 03:12 PM
