1. Larry Lott's Avatar
    My phone makes a noise when I plug the charger into it or disconnect it. Is there a way to stop this noise? It also makes a noise when I turn the video camera on or off. Is there a way to stop this noise also?
    11-11-2014 02:33 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! Do those sounds get muted if you turn the phone to Silent Mode or Vibrate Mode? Otherwise, you'd probably have to root the phone and install something like Xposed Framework to modify that. I don't know the details, though.
    11-11-2014 02:36 PM
  3. Larry Lott's Avatar
    Yes. The sounds go away when I mute the sounds but then I have no sound on my video recorder.
    11-11-2014 02:44 PM
  1. What is the best way to charge the tablet?
    By lbabus in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 12-11-2014, 10:37 PM
  2. Replies: 6
    Last Post: 11-16-2014, 09:53 PM
  3. Replies: 4
    Last Post: 11-12-2014, 09:25 AM
  4. Replies: 1
    Last Post: 11-11-2014, 02:40 PM
  5. Why won't Google services connect to internet?
    By Antony Prentice in forum Google Play Store
    Last Post: 11-11-2014, 02:25 PM
