1. TheFatDroid's Avatar
    I want to get a nexus 7 2013, I read that it has qi wireless charging. I was wondering if I put a case, like a silicone type case, on this tablet, will the case block qi wireless charging from working?
    11-14-2014 04:06 PM
  2. Rukbat's Avatar
    I run my Note 3 with a TPU case and it charges nicely (even though the case does measure a bit thicker than 5mm, which is supposed to be the standard. I get the same 600mA charge current whether the case is on or off. So I'm guessing that it should work with your silicon case.
    11-14-2014 04:29 PM
  1. Replies: 38
    Last Post: 11-20-2014, 08:05 AM
  2. Nexus 5 wireless charger work with Turbo?
    By s1w in forum Motorola Droid Turbo
    Last Post: 11-17-2014, 04:54 PM
  3. HTC One M8 charging question
    By wobourt in forum HTC One M8
    Last Post: 11-15-2014, 11:34 PM
  4. Replies: 3
    Last Post: 11-14-2014, 04:00 PM
  5. Replies: 0
    Last Post: 11-14-2014, 03:17 PM
