1. Anthony Casotti's Avatar
    Hey ya'll,
    I got a galaxy S4 for Christmas a about a year ago and I loved the long battery life it had. Recently, my battery hasbt lasted anywhere near to what it used to. Before it started to not last very long, my stock charger broke so I used my moms old kindle charger. It charged my phone really fast and i think thats the reason why it doesnt last very long. And its nit the battery itself, its the phone. Any ideas as to why it wouldnt last as long?
    11-16-2014 09:37 AM
  2. belodion's Avatar
    Welcome to AC.☺
    The S4 is a good phone and it deserves a good battery and charger. Have you taken a look at the battery? If it's bulging at all, it's certainly failing. Even if flat, I'd suspect battery before phone. But if it is the phone, three things that might help are 1) Clearing the app cached data in Settings, Storage; 2) Wiping the Cache Partition in Recovery; 3) Factory Resetting, also in Recovery....of course all personal data not backed up will be lost with this option.
    It may also be worth checking your battery stats to see what's using charge. There may be something abnormal going on which is causing drain.
    Golfdriver97 likes this.
    11-16-2014 09:58 AM
  3. Golfdriver97's Avatar
    Welcome to the forums. How did you eliminate the battery as the reason?
    11-16-2014 10:01 AM
  4. srkmagnus's Avatar
    Hey ya'll,
    Do you notice any unusual battery usage in the battery stats? What about a factory reset? Have you performed one since purchasing the device? It seems like something is causing battery drain. If you can't pinpoint the problem through the battery stats, then consider a reset. Be sure to sync and backup data beforehand since it will erase everything except the SD card.
    11-16-2014 10:01 AM
  5. Anthony Casotti's Avatar
    I eliminated the battery as a cause because i have purchased a backup battery and it last the same amount of time.
    11-16-2014 12:29 PM
  6. Golfdriver97's Avatar
    Did you get an update recently? Can you post screenshots of your battery stats please?
    11-16-2014 01:25 PM
  7. Rukbat's Avatar
    Install Galaxy Charging Current Lite. Plug the charger in. (Press Refresh if no charge is showing.) Unless the charge is more than 2600 (1 times the capacity of the battery, or 1C), there's nothing wrong with using the charger. (And I doubt that the Kindle charger is capable of anywhere near that. Your old S4 charger may have been defective, so the Kindle charger charged faster.)
    As Golfdriver said, we need screenshots of both pages of your battery stats to have a chance of diagnosing the problem.
    11-16-2014 02:13 PM
  8. Anthony Casotti's Avatar
    Is this the battery stats?
    Attached Thumbnails Samsung Galaxy S4 battery issue-screenshot_2014-11-16-14-35-17.jpg
    11-16-2014 02:36 PM
  9. Golfdriver97's Avatar
    Yes. Aside form the cell signal, not much seems out of the ordinary. It is possible the charger may have damaged the USB port.
    11-16-2014 06:40 PM
  10. Rukbat's Avatar
    Let the phone sit for a few hours, turned on and not charging. (Charge it first, though, with the power off - 27% is a bit low to let the battery get to.) Then go to that screen and press the graph. Look at the Awake line at the bottom. If it's not almost all black, install Wakelock Detector to see what's keeping the phone from sleeping (which eats a lot of battery).
    11-17-2014 12:27 AM
  11. John Milne's Avatar
    Hi. I'm new to this forum but thought I'd share my experience as its similar to those posted. I have a Samsung galaxy s4 (on 3 mobile) which had previously had excellent battery life and following the kitkat update, the battery started draining from unplugging it at 7am to being flat/dead at 5pm.
    I ended up buying a new battery (samsung original) and it made absolutely no difference - still couldnt get a days work out of the phone even with very light use.
    This week i noticed the standard email app (i'm using sky email) was constantly refreshing so i disabled that app and my gmail app and the battery life has gone back to the way it was before. Its currently 10:58pm and my battery is sitting at 46% after taking it off charge this morning! I'm currently using google inbox as my mail client and everything seems fine.
    belodion likes this.
    11-19-2014 05:00 PM
  12. belodion's Avatar
    Welcome to the forums.☺
    Thx for sharing....your experience may be of help to others and in fact has already given me something to think about as a possible solution to a problem I've got myself at the moment.
    11-19-2014 06:36 PM
  13. Gobucks1234's Avatar
    I just got two batteries online for twenty bucks. That seems to be the easiest check. Also if you press hold home button and press the pie chart you can check active apps. I had Firefox app and it would constantly use 40 percent of cpu. Uninstall Fixed my battery drain.
    11-19-2014 09:45 PM
  1. Is this battery life 'normal'?
    By bthere79 in forum Google Nexus 7 Tablet (2012)
    Last Post: 11-17-2014, 05:03 PM
  2. Replies: 1
    Last Post: 11-17-2014, 04:39 PM
  3. Is the issue with SD cards and apps still out there?
    By raxnw in forum Android 4.4 KitKat
    Last Post: 11-16-2014, 02:47 PM
  4. Sudden Note 3 battery drain due to Gmail
    By blanier98 in forum Samsung Galaxy Note 3
    Last Post: 11-16-2014, 10:29 AM
  5. galaxy note 4 widgets don't complete loading on page
    By Donn Clark in forum Samsung Galaxy Note 4
    Last Post: 11-16-2014, 08:48 AM
