1. rejectedpotato's Avatar
    I know it has something to do with my wire but I don't know nothing about electricity n' stuff. Is there a way to see how much power is going into my phone through the wire? And what should it be
    ? I have a galaxy s4 (SGH-1337M)
    http://imgur.com/fJXfbYk
    11-16-2014 08:23 PM
  2. Rukbat's Avatar
    Galaxy Charging Current Lite will show you the charging current, but it won't show you how much of that is being used to charge the battery and how much is being used to run th phone. (For instance, if the phone is using 700mA and the charge current is 600mA, you're draining 100mA out of the battery every hour - with the charger plugged in. If the charger weren't plugged in you'd be draining 700mA from the battery every hour.)
    Charge the phone overnight with the phone turned off. If it hasn't recharged by morning, there's a problem. If it has there isn't.
    11-17-2014 12:06 AM
  3. rejectedpotato's Avatar
    I noticed for some reason when charging it is slowly draining less/charging more over time
    Ex: when I plug it in it is discharging ten minutes later it is finally charging but very slowly and then about another 10 minutes later it is charging at an acceptable speed. My battery also drains at about 5%/h which is pretty bad and it has been going on since I updated my firmware but the discharging while plugged in hasn't been a problem sense yesterday. Its not a problem with an app or my cache.
    11-17-2014 03:34 PM
  1. Why is battery life so bad on stock?
    By Tex_Norseman in forum Verizon LG G2
    Last Post: 11-18-2014, 01:28 PM
  2. Does having nfc on actually drain battery
    By mvasquez009 in forum General News & Discussion
    Last Post: 11-18-2014, 10:58 AM
  3. Replies: 7
    Last Post: 11-17-2014, 02:40 PM
  4. How much does Web browser hammer the battery?
    By thegame161 in forum Samsung Galaxy Note 4
    Last Post: 11-17-2014, 07:39 AM
  5. Why is my battery draining so fast?
    By docsmody in forum Samsung Galaxy S4
    Last Post: 11-16-2014, 06:48 PM
