1. Chaumander's Avatar
    I tried searching for threads about this, but couldn't come up with anything.
    I installed Gsam Battery Monitor on my new Droid Turbo, and opened the app. I waited about 10 minutes and checked the calculating status, and everything was still calculating. I went ahead and cleared the cache/app data hoping that would help, but after opening the app back up and waiting 30 minutes, nothing has changed... Is this normal? Something wrong?
    Any help would be great! Thanks.
    11-21-2014 10:39 AM
  2. belodion's Avatar
    When I installed that app, I had no such problem with it. Is it possible you have some other app on board that may be interfering with its normal function? Failing that, it may be worth uninstalling and re-installing.
    11-21-2014 12:05 PM
  1. Replies: 41
    Last Post: 03-09-2015, 09:18 AM
  2. TWC (Time Warner Cable) App Not Working
    By rgeese in forum Google Nexus 10 Tablet
    Last Post: 11-26-2014, 10:30 AM
  3. Quiz: Battery Saver or Not?
    By LezCronut in forum Android 5.0 Lollipop
    Last Post: 11-21-2014, 05:28 PM
  4. Replies: 1
    Last Post: 11-21-2014, 10:27 AM
  5. Replies: 1
    Last Post: 11-21-2014, 09:54 AM
