1. Vita Kolosilek's Avatar
    Watss up adroinds ?
    I have one problem, I need to turn on the light when I am using front camera ..
    Do you guys know, how to do it ?? I asked everywhere on the world, but nothing...
    I need it for one accessories..
    I have S3, but I thing, will be same way on Samsung's phones to do it..
    Thanks a lot !
    11-21-2014 10:31 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! That might be difficult to achieve. Flashlight apps work by controlling the camera (since the LED flash is part of the camera). But if you open the Camera app, the flashlight app won't be able to connect to the camera, and thus you won't be able to turn on the LED as a flashlight, even if you're only using the front-facing camera. Conversely, if you have the flashlight turned on first, and then try to open the Camera, you'll get an error telling you that the Camera can't be accessed (since it's being used by the flashlight app).
    11-22-2014 12:56 AM
  1. Anyone use the tap n go feature to upgrade?
    By davey11 in forum Google Nexus 6
    Last Post: 12-03-2014, 09:08 PM
  2. Replies: 5
    Last Post: 11-22-2014, 08:28 AM
  3. metal rim on note 4 faded.
    By saiyyasuka pon in forum Samsung Galaxy Note 4
    Last Post: 11-22-2014, 08:01 AM
  4. Anyone experiencing smartwach problems with the Moto G
    By sabin1101 in forum Moto G (2014)
    Last Post: 11-21-2014, 10:23 PM
