1. Ali Koenig's Avatar
    I have a Galaxy Note ll I was having battery issues where once it reached about 30% it would die in twenty minutes. I mentioned this to someone and he rooted my phone for me and did some things to "fix it", but now my phone is completely messed up. After he fixed it he told me to charge it to 100%, use this battery calibration app, let it completely run out of battery, then charge it to 100% after it died while it was still off. I did this, restarted my phone and used it like normal, then a few hours later my phone started freezing up, the battery jumped from 50% all the way to 17% percent and kept locking up. I have no idea what to do.
    11-23-2014 09:16 PM
  2. STARGATE's Avatar
    Hello and welcome to the forums at Android Central! 🙋
    Did you check the battery, did it feel or look swollen?
    If it did, the battery isn't good anymore.
    11-23-2014 09:43 PM
  3. Ali Koenig's Avatar
    The battery looks the same as it has always looked, I am not a very tech-savvy person, but I feel like that is a joke...?
    11-23-2014 09:45 PM
  4. STARGATE's Avatar
    No joke, if the battery it's swollen, it's not good at all anymore.
    11-23-2014 09:55 PM
  5. STARGATE's Avatar
    You mention a calibration app. What did it say, it's the battery in good shape?
    Take the battery out, wait for a few minutes, than put it back in (without turning the phone on), charge it up to 100%.
    Unplug it, turn it on, see how it works.
    11-23-2014 09:57 PM
  6. Ali Koenig's Avatar
    Once it started freezing up, I tried taking my battery out several times. I didn't charge it while it was off though, other than the first time, does that make any difference?
    Also, when I turn it back on after it dies on me it says I have a higher battery amount. The last time I did it, it had been stuck at 3% for twenty minutes, it locked up, after waiting ten minutes I took the battery out for a bit, and turned it back on, it then said that I had 14% battery.
    11-23-2014 10:07 PM
  7. STARGATE's Avatar
    Sounds like the battery is the culprit, not the phone.
    Still, let me ask the guys, maybe one of them has a solution.
    11-24-2014 06:46 AM
  8. dpham00's Avatar
    Was it locking up before it was rooted?
    Sent from my Verizon Samsung Galaxy Note 4
    11-24-2014 07:49 AM
  9. GregMargie's Avatar
    Sounds like the battery to me as well. My Note 2 original battery has been draining really fast the last couple weeks as well and getting worse every day! I started this morning taking my phone off charger and in 1 hour am down to 43%! I am waiting on my ordered Note 4 to arrive!
    Wondering if your friend rooting your phone may have messed it up in addition to bad battery.
    11-24-2014 09:19 AM
  10. Rukbat's Avatar
    See How can I fix my battery after it has been rooted? for a full explanation. She has more than 1 thread on this problem.
    11-24-2014 09:56 AM
  1. locked Samsung galaxy s4 :(
    By jjsang in forum T-Mobile Samsung Galaxy S4
    Last Post: 12-28-2014, 02:47 PM
  2. Replies: 6
    Last Post: 11-24-2014, 08:25 AM
  3. Note 4 not charging
    By Brandwin in forum Samsung Galaxy Note 4
    Last Post: 11-24-2014, 12:52 AM
  4. Why am I having issues with my Note 2 since the LCD screen replacement?
    By Charles Crosno in forum Samsung Galaxy Note 2
    Last Post: 11-23-2014, 08:53 PM
