1. Etrain75's Avatar
    Can anyone give me some tips on how to set it up? My device isn't supported and I do not want to try a manual install on my own. Can someone also tell me what it exactly does? I kind of know but I'd like some clarification. So it creates a backup OS that you can fall back to if **** hits the fan am I right? You can also flash custom OS on it from what I can gather. Thanks!
    11-24-2014 09:25 PM
  2. wizzrah's Avatar
    Hello. I don't see any version of CWM for your device. The closest lead to one I could get was this:
    http://forum.xda-developers.com/andr...m-rom-t2874355
    Now, CWM is GUI recovery used to flash files, create backups, and more, all outside the default OS.
    If you have more questions, let me know.
    Etrain75 likes this.
    11-24-2014 11:52 PM
  3. Etrain75's Avatar
    I'll be sure to look into that! Thank you very much!
    11-27-2014 06:48 AM
  4. wizzrah's Avatar
    No problem! Again, don't be afraid to ask questions. I'll be happy to help you out.
    11-28-2014 12:47 AM
  5. daddycator69's Avatar
    hi Etrain ,can you please post the backup OS off cubot s308? i got my phone "super super bricked " and im try to fix it with MTKdoid tool ,,SpflashTools and a tutorial on Youtube but im missing that backuuupp!! What i need is the file "fimware.info" that MTkdoidT needs to run. I had download a Custom rom somewhere but does not contain that file. I guess it was on Needrom,but they only h<ve a custom rom fo KitKat vesion ,,mine is JB and i guess it doesnt wok well...
    06-13-2015 10:11 AM
  1. speakerphone only on bottom speaker?!
    By techaddict2 in forum Sony Xperia Z3
    Last Post: 12-28-2014, 09:50 AM
  2. My Samsung Galaxy tab 3 won't turn on or chrage, help?
    By eckeryb in forum Samsung Galaxy Tab 3
    Last Post: 12-19-2014, 12:05 AM
  3. Replies: 1
    Last Post: 11-25-2014, 05:33 PM
  4. Photo Editor by Aviary: $200 of free add-ons
    By mightyfacundo in forum Motorola Droid Turbo
    Last Post: 11-24-2014, 11:41 PM
  5. dialing on its own
    By vbslim in forum Motorola Droid 4
    Last Post: 11-24-2014, 07:47 PM
