Need help with Samsung Galaxy Grand 2 storage
I just installed GTA San Andreas from the Google Play store on my phone which used up 2.4GB of space that left me with only 600MB out of 8GB of storage space. After a while I decided to uninstall it so I dragged and dropped it to the "Remove" icon on the phone. But my storage didn't go up, the app has been uninstalled since I cannot find it on my phone and when I go to the "Google play" store for GTA San Andreas, it will ask me to install it since I had purchased it. So that indicates I already uninstall the application but my storage still didn't went up. I can't even Install GTA San Andreas anymore from the "Google Play" store because of "insufficient storage" but it worked the first time before. I plugged my phone to my computer and didn't find any files related to GTA San Andreas (enabled hidden file). I also checked my Storage information, it says I have a Total space of 8GB. 2.83GB for System Memory which is important and can't be deleted, 4.2 Used Space, 104MB Cached Data, 28MB Misc files and ends me up with 525MB. I clicked on the "Used Space" and I was definitely NOT using 4.2GB. In the Used Space tab, I was using 1.66GB on Apps, 9MB on Pictures and Videos, 148KB on Audio and 23MB on Downloads.
