1. ElvDaKing's Avatar
    Hi everyone. So i decided to upgrade from my standard Broadband (sky)to 38Mbps Fibre (TalkTalk). First thing i did was to try wired connection in my laptop, im getting about 25mbps and 15mbps wireless. Now my laptop is old and my wife has bought me a new HP 15 for xmas so i will wait and see on that but its my samsung note 4 which is driving me mad. My sons Lenovo Tab 10 is pulling 30mbps everytime and so is my wifes iphone 6 yet my Note 4 flicks round to 30ish for a split second and then drops to 15mbps or lower. Ive tried a reset on my mobile which made no difference, ive turned off 2.4ghz and 5ghz to see if it changes but no joy. changed channel with no effect so im very frustrated!
    The router
    SuperRouter Specifications
    • ADSL2+ & VDSL2 (Fibre ready) modem
    • 3×3 MiMo; Simultaneous 2.4Ghz and 5Ghz dual-band
    • 5Ghz with Wi-Fi AC, backwards compatible with Wi-Fi b/g/n
    • 2.4Ghz with Wi-Fi N, backwards compatible with Wi-Fi b/g
    • One touch Wi-Fi Protected Setup (WPS)
    • WEP & WPA2 Wi-Fi security
    • 4 x RJ45 Gigabit Ethernet LAN ports
    • 1 x RJ11 xDSL port; 1 x RJ45 WAN port
    • Integrated firewall; Integrated Self-Help pages
    • 1 x USB 2.0 host for external storage and printers
    • UPNP with port forwarding and mapping
    • DLNA
    Any help would be great, Matt
    11-26-2014 05:53 AM
  2. VidJunky's Avatar
    I don't know I only looked at two articles and it doesn't sound like the Note4 is a big performer.
    Wi-Fi performance is also excellent here: In side-by-side tests, from about 50 feet away from a router in a crowded office, the Note 4 averaged 14.08Mbps down and 3.6Mbps up versus the iPhone 6 Plus's 8.01Mbps down and 1.75Mbps up.
    Samsung Galaxy Note 4 (AT&T) Review & Rating | PCMag.com
    Note 4 - WiFi Performance is worse than the … | Samsung Galaxy Note 4 | XDA Forums
    11-26-2014 07:25 AM
  3. Adil Shahzad's Avatar
    i have newly purchased note 4 ,2 weeks ago,and now i got a problem,my wifi is connected to wifi device.but working very slow
    and suddenly drop the signal & appears network error,its keeps on drop & caught the signal,and sometime does not work completly,i have done reboot,factory reset many times,but same issue,anybody has a solution for that?
    01-21-2015 12:09 AM
  1. Replies: 2
    Last Post: 11-29-2014, 08:08 PM
  2. Why are my Viber and Skype calls only ringing once?
    By Ha-meem Ahmad in forum Ask a Question
    Last Post: 11-26-2014, 05:26 PM
  3. Replies: 1
    Last Post: 11-26-2014, 05:03 PM
  4. Comfortable clothing with room for Note 4
    By isabel95 in forum Samsung Galaxy Note 4 Accessories
    Last Post: 11-26-2014, 11:56 AM
  5. How do I fix my tablet which is stuck in boot-loop?
    By forrestman in forum Ask a Question
    Last Post: 11-26-2014, 07:02 AM
