1. RON SANDY's Avatar
    since i did it my phone gets warm quickly just sitting there no apps brightness 0. I lose 1% every 5-6 mins before it 1% an hour and adroid systems are at 20%+ did i do something wrong.
    11-26-2014 10:17 AM
  2. belodion's Avatar
    Probably not. Perhaps something has triggered Android OS, or something else. Could you post a screenshot of your battery usage stats at the end of a day's use, before you recharge? Also touch the battery usage graph to open it, showing mobile signal, wifi etc at the bottom, and also post a screenshot of that? Please mention also your screen-on time, and typical brightness.
    11-26-2014 11:56 AM
  3. RON SANDY's Avatar
    Here are the stats
    Attached Thumbnails Why is my phone battery losing power so quickly since I did a reboot (S5)?-screenshot_2014-11-26-14-41-26.jpg   Why is my phone battery losing power so quickly since I did a reboot (S5)?-screenshot_2014-11-26-14-41-35.jpg   Why is my phone battery losing power so quickly since I did a reboot (S5)?-screenshot_2014-11-26-14-44-03.jpg
    11-26-2014 12:44 PM
  4. belodion's Avatar
    Did you only charge it to 20% capacity rather than 100%? If so, that is not good practice, as well as being impractical. Battery experts on these forums have taught me to recharge when the battery has discharged to no lower than about 40%, and I trust them.
    The app percentages look normal enough, and the screen-on time actually looks quite good starting from that 20% charge. A discharge to 6% with that much use in that much time seems okay to me....but again I don't see why you did not charge fully.
    The mobile signal is not the best, which will tend to use battery, although I don't know that it would cause overheating. Could you charge to 100%, use normally, and post more stats as above?
    Try turning mobile data off for a while and see whether the overheating stops. That signal looks abnormal to me.
    11-26-2014 03:22 PM
  5. Rukbat's Avatar
    Also the phone is awake far too much. Install Wakelock Detector and see what's keeping it awake. Install Greenify to hibernate (temporarily freeze, until you run them) apps that are keeping the phone awake that shouldn't be. (Alarms, email, etc., should be - they have to wake up periodically to see if it's time to do something. Your Contacts app doesn't need to run until you run it.) Keeping the phone awake too much kills the battery quickly. (And that 40% figure belodion mentioned comes from Battery University - How to Prolong Lithium-based Batteries, the battery analyzer company. 50% is the ideal point, but to be realistic I say 40% to 60%.)
    11-26-2014 04:36 PM
  1. Replies: 3
    Last Post: 12-01-2014, 12:15 AM
  2. Can anyone help me with some Android 5 issues on Nexus 4?
    By Sandy Gum in forum Ask a Question
    Last Post: 11-26-2014, 10:08 PM
  3. next launcher app for s5 active
    By jared316 in forum Samsung Galaxy S5
    Last Post: 11-26-2014, 06:32 PM
  4. Replies: 2
    Last Post: 11-26-2014, 03:57 PM
  5. How is the Galaxy S5 compatibility with ATT LTE?
    By robhir in forum Samsung Galaxy S5
    Last Post: 11-26-2014, 02:24 PM
