1. steveie's Avatar
    droid turbo when plugged in with factory charger it shows battery with lightning bolt,then vibrates, then shows battery with question mark in it, and was plugged in all night, wont power up, please help its thanks giving and no one can call me!!!
    11-27-2014 06:55 AM
  2. belodion's Avatar
    If you can, check that the battery is making good contact.
    But it could mean that the battery has failed.
    11-27-2014 01:40 PM
  3. Golfdriver97's Avatar
    Try a different cable and charger. Even a different cable and your PC.
    From an AOSP M8
    11-27-2014 05:22 PM
  4. steveie's Avatar
    thanks but ive tried different chargers and computer, no luck, only had phone for a month ,have to bring it to a Verizon store tomorrow and get a knew one.
    11-27-2014 07:05 PM
  5. steveie's Avatar
    I don't like that phone doesn't come apart,
    11-27-2014 07:08 PM
  6. steveie's Avatar
    for future if anyone needs a factory reset,if you hold power button and volume down at the same time for 2 minutes it should work.it did not work for me and knew phone on the way ,thanks for your help.
    11-29-2014 05:57 AM
  1. 0 Power Save Mode
    By Murph5150 in forum LG G3
    Last Post: 11-28-2014, 09:22 AM
  2. Power users s5 vs note 4?
    By bplink95 in forum Samsung Galaxy Note 4
    Last Post: 11-27-2014, 06:10 PM
  3. Why does my Note 4 screen have a wake up lag?
    By hormelonabun in forum Samsung Galaxy Note 4
    Last Post: 11-27-2014, 06:50 AM
  4. Should I drain my Droid Turbos battery on first charge?
    By Seremedy in forum Motorola Droid Turbo
    Last Post: 11-27-2014, 05:29 AM
  5. Replies: 1
    Last Post: 11-26-2014, 11:45 PM
