1. Vivek Ece's Avatar
    i bought a moto g2 on 22-11-2014.. battery hardly seems to stand for around 6 hours only if i were using mobile without internet....during the usage of internet battery drains nearlly 30% per hour ..is it normal????? what should i do????? i wouls turn off my mobile data and all my background running apps even after dng it i face the same problem every day...someone plsss help me....???plssssssssss
    11-28-2014 01:03 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! It would help to see some battery stats. Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/amb...d-central.html
    In the meantime, review this guide: http://forums.androidcentral.com/amb...ving-tips.html
    11-28-2014 02:27 AM
  3. Vivek Ece's Avatar
    11-29-2014 02:06 AM
  4. B. Diddy's Avatar
    Sorry, but what I suggested was to let it drain down to 20% (i.e., use up 80% of your battery). It's more useful to see what's been going on over the course of a whole battery charge, rather than just 20% of it.
    Vivek Ece likes this.
    11-29-2014 03:21 AM
  5. Javier P's Avatar
    As Diddy said, just 20% of use is not enough for a good analysis. But looking at your stats everything looks fine so far.
    The screen on time (1:20) is good for that battery percentage. Specially if most of it was used with Whatsapp, as it seems. You must expect 5-6 hours of screen on depending the apps you run. Typing a lot or heavy games are going to consume more than just reading, for example.
    Let's wait for the stats that Diddy said though.
    B. Diddy and Vivek Ece like this.
    11-29-2014 05:47 AM
  6. amazed2025's Avatar
    Well putting down your brightness and turning off bluetooth and other services which you don't need should drastically help, but do what these guys are saying ^
    11-29-2014 08:38 AM
  7. Vivek Ece's Avatar
    Sir thanks for ur solutions ...... I have an another problem now ... In my mobile android os part takes more of my internet data whenever I turned on my mobile data ... Y is this happening how can I stop this???????
    Attached Thumbnails How can I stop my mobile battery draining so rapidly?-5774.jpg   How can I stop my mobile battery draining so rapidly?-5773.jpg
    12-05-2014 11:16 AM
  8. Rukbat's Avatar
    22MB is hardly a lot. Leave it on for 24 hours and you'll probably see that it doesn't use much more, if any. Every once in a while, Android OS uses a bit of data. (Keep the phone on wifi as much as possible if you don't want to use mobile data. If you don't need the internet when you're not near a wifi connection, just keep mobile data turned off unless you absolutely need it.)
    12-05-2014 05:10 PM
  9. Vivek Ece's Avatar
    Sir, my android os is still consuming my mobile data now it has reached 40 MB how can I stop this???????? pls help me sir
    Attached Thumbnails How can I stop my mobile battery draining so rapidly?-6027.jpg
    12-06-2014 11:20 PM
  10. MaLik Hadi's Avatar
    i think 30 percent per hour with constant 50% brightness and 3g is normal
    Posted via note 3
    12-07-2014 09:44 AM
  11. Golfdriver97's Avatar
    I think if you click the 3 dot menu on the main list, you can limit background data. Try that and see if it helps.
    12-07-2014 10:00 AM
  12. Javier P's Avatar
    I think there's not an easy way to restrict background data for Android OS. And it is difficult to know which processes are included in it.
    Most people say that backup data is there, so you could try to uncheck that in backup & reset for a couple of days and see what happens.
    A couple of things you could try. Go to every app that sync/upload and select in the settings just to do that with WiFi. There are some apps, like Google + that you can even set to sync just when the phone is charging. Play store, FB, mail, etc. are others to check the sync settings.
    Try to avoid Widgets that update data very often. Other apps could be news/rss readers. Keep the refresh settings when just in use.
    So that's your next job mate
    Tiding up your background settings.
    Golfdriver97 likes this.
    12-07-2014 01:15 PM
  13. Rukbat's Avatar
    34MB still is almost nothing, but you can turn Mobile Data off, then it won't consume any data at all. And stop using apps that need data connections (Whatsapp, UC Browser) when you're not on wifi.
    12-07-2014 03:36 PM
  14. Javier P's Avatar
    Well, that's a bit radical, isn't it? It's not about limiting your use while on mobile, but just trying to keep your background usage under control. And if you see in the OP screenshots, the Android OS data it's just background.
    I can understand his worries. When you have a cheap limited data plan (as I have), that daily usage can be a problem.
    12-07-2014 04:02 PM
  15. B. Diddy's Avatar
    I think both Javier P and Rukbat have good suggestions, and which one is best depends on the user's preference. You can definitely look through a lot of the various system and app settings to turn off things like automatic data syncing and Location Reporting. But as was also mentioned, it may not be possible to turn off all data usage by the OS, because mobile platforms are becoming increasingly dependent on communication with servers on the web. I agree that toggling Mobile Data completely off is a reasonable option, especially if you have a limited data plan, because in that situation, you want to do anything you can to conserve your data. Unless you need to be constantly connected (i.e., alerted immediately when you get an email, or a Facebook update, or an MMS message), it should be reasonable to keep Mobile Data off, and only turn it on when you want to check on that kind of information.
    Javier P likes this.
    12-09-2014 12:23 AM
  1. Can I get some help syncing my Note 3 to my Outlook calendar?
    By peterpanmalta in forum Samsung Galaxy Note 3
    Last Post: 03-17-2015, 02:39 AM
  2. Can anyone help me with some Note 2 woes?
    By futhashi in forum Ask a Question
    Last Post: 11-29-2014, 11:43 PM
  3. Replies: 1
    Last Post: 11-29-2014, 02:02 PM
  4. only real frustration so far besides battery
    By currentdroiduser in forum Samsung Galaxy Note 4
    Last Post: 11-28-2014, 01:18 AM
  5. Replies: 1
    Last Post: 11-28-2014, 12:30 AM
