Need help to ID an app that disappeared from my LG G2
2Etech
5
A photo editor app that came with my lg g2 has disappeared from my phone. Unfortunately, I don't remember its name, but I
want it back because I liked it. One of the editing effects was called "drama".
belodion
Co-Ambassador Team Lead
Moderator
Jun 10, 2014
39,389
254
83
Welcome to the forums.☺
'Drama' is one of the photo editing options available when you edit in Photos or Gallery, to the best of my ability to recall Kitkat 4.4.2 which I imagine is what your G2 is running. Are you not able to open the Edit option in either of those?
2Etech
5
First of all, thanks for the welcome and the reply!
Yes, I am running KitKat.
This was a separate app for editing photos because when I would enter the menu when viewing a picture and select edit, it would give me two apps to choose from, but one day, out of the blue, the second app option was no longer available. What I am assuming is that the app was some kind of trial app that came with the phone. I still have the gallery photo editor, which I don't like as much.
belodion
Moderator
Jun 10, 2014
39,389
254
83
I see. Well on Lollipop on my Nexus 5, there is no longer Gallery, only Photos. Doh!
Someone may pass by here who knows what you're looking for, but I recommend posting also in the LG G2 forum, where I imagine other users will know what app you're referring to. :)
2Etech
5
I have discovered what happened to my 'Photos' app.
A while back, I was attempting to improve my battery life and reduce data usage by disabling apps that were running in the background.
I ended up disabling Google+ because I wasn't using it anyway (or so I thought).
After doing an app search for "Google photos" in Google Play, the Google+ app showed up in results and was labeled as disabled.
On a whim, I enabled Google+ in my app manager.
Both Google+ and Photos now appear, side by side, in my apps list.
Opening the Photos app, a photo editing icon labeled "Drama" is located on the bottom of the screen.
I now realize that Photos is the app that I had been missing, and is, apparently, inseparable from Google+
I hope this helps someone else who might have the same problem.
belodion, thanks for your help.
kerokekerol
