02-15-2016 04:30 PM
34 12
tools
  1. doch69's Avatar
    Mobile Samsung s 4 mini....... TV Samsung UE40H6400 - 40" - 6 Series 3D LED TV - Smart TV
    12-01-2014 11:25 AM
  2. belodion's Avatar
    Welcome to the forums.☺
    Have you tried a Cache Partition wipe, or even, if your personal data is backed up, a Factory Reset?
    12-01-2014 03:24 PM
  3. doch69's Avatar
    Thanks for quick reply belodion ,yes i have used Cache Partition wipe, and the Factory Reset. still get failed to mirror.... Before the KitKat 4.4.2 upgrade .it did work .My Wifes mobile phone Samsung S5 works via mirroring she use KitKat 4.4.2 (remembering mine is the Samsung S4 mini)
    12-01-2014 04:02 PM
  4. Rukbat's Avatar
    Very strange, since that's the only thing mirroring is supposed to work with on a Samsung phone, a Samsung TV. (The rest of us have to buy Chromecast to mirror.) I'd first (if you're in the US) go to Best Buy and find the Samsung Experience desk and ask them for help. (It's possible that the update glitched just in the mirroring firmware - they can reflash it for you.) If they can't help you, they probably have the phone number of Samsung's real tech support (not the people who type the question into a computer and read you the answer), and they (Samsung) should be interested that they broke one of their advertising points. They won't sell a lot of TVs if updating your Samsung phone makes it just another TV.
    12-02-2014 12:42 AM
  5. doch69's Avatar
    Thanks Rukbat yes it seems to be only affecting the mini S4. will contact like you said Real tech support at Samsung in uk .
    12-02-2014 06:24 PM
  6. Luis Vieira's Avatar
    Hi,
    I also have the same problem. Samsung S4 Mini... Before kitkat screen mirroring worked fine... I used every single day... after received the kitkat update never worked again... i am able to connect to the samsung smart tv but after a couple of seconds I receive an error on the mobile saying that it;s not possible to share via screen mirroring and exits....
    I also did the reset factory and clear cache but no joy.
    Did you had any feedback from samsung tech support?
    Mobile: Samsung S4 Mini I9195
    TV: Samsung SmartTV 42"
    12-03-2014 03:10 PM
  7. doch69's Avatar
    Spent one hour on land line phone with Samsung tech support this morning only to be told, that i will have to send in my S4 mini to to be repaired as they think it's a fault with the S4 mini , and as of 11 am this morning they had 5 complaint calls about the lack/loss of mirroring with Samsung TV 's.
    12-04-2014 08:41 AM
  8. Luis Vieira's Avatar
    I don't think is a fault with the samsung s4 mini... before the kitkat upgrade worked fine... it's a fault with the kitkat upgrade not the mobile...
    So they release a new firmware, people like us press the button to upgrade, then the screen mirroring stops working and the fault is with the mobile? Does't make any sense... if it was working before the upgrade was the upgrade that made the fault not the mobile...
    I also call samsung but i just give up when they forward my call to the tv support saying that i needed to reset my tv.... waste of time...
    12-04-2014 01:14 PM
  9. Rukbat's Avatar
    $25 solution - buy a Chromecast. (Best Buy has them for $25 this holiday season.)
    12-04-2014 02:10 PM
  10. alam18305's Avatar
    Hi I have bought a samsung mhl 2.0 adapter from eBay but not sure if it's geniune. Tried it on my samsung alpha doesn't even recognise it however tried the adapter on a s5 it's recognised. Can anyone advise me if there is a cable I could use to connect my phone to a tv? Thanks
    12-04-2014 02:26 PM
  11. doch69's Avatar
    That is what i said to tech guy it doesn't make any sense ,as all worked fine before the upgrade to kitkat 4.4.2 (tech guy has simply passed the problem to someone else)
    12-05-2014 08:57 AM
  12. Luis Vieira's Avatar
    Amazing... the goal or deploying new software is to improve things not to break... Let me know if you find any solution... I will do the same if I find any workaround to the problem....
    12-05-2014 10:03 AM
  13. Knockoutbffs's Avatar
    I have a note 4 and it will only mirror pictures and apps to my vizio smart tv but none of the movies I have on my phone. In fact it wont even give the option to mirror.
    12-05-2014 11:04 AM
  14. Rukbat's Avatar
    Mirroring on a Samsung phone ONLY mirrors to a Samsung smart TV. For any other TV brand (I have a Vizio too) use Chromecast. Mirroe the phone to the Chromecast device, then run any app you want - it'll be on the TV.
    12-05-2014 05:16 PM
  15. doch69's Avatar
    I sent mobile to be repaired (as told to do by tech guy) they sent it back saying all phone updates software Done.But guess what mirroring still not working,have had to send phone back to be checked ,but this time i wrote in English and Spanish that the android KitKat4.4.2 has a bug/glitch when using the S4 mini after update why Spanish you ask., when i got the mobile back everything was in Spanish.
    12-25-2014 04:52 PM
  16. doch69's Avatar
    Well what a surprise they have sorted out the bug/glitch with the S4 mini Android (well my one) it would be interesting to find out how many had same problem etc.Remember to off automatic updates i will in future
    12-29-2014 06:32 AM
  17. Tuicu Liviu Laurentiu's Avatar
    I have the same issue. Has been solved? how?
    12-30-2014 06:11 PM
  18. doch69's Avatar
    Yeah has been solved,They fixed the kitkat 4.4.2 software issue, after i explained in writing what the problem was,as mentioned above , phone was returned to me with mirroring working
    12-31-2014 11:52 AM
  19. KarliAndi's Avatar
    I have the same problem, any ideas how to fix it?
    01-03-2015 04:46 PM
  20. Yth22's Avatar
    Hello,
    Same problem to me : S4 mini, Samsung TV, screen mirroring stops working after upgrade 4.4.2 . Android French version .
    Any patch or other solution ?
    01-10-2015 03:21 AM
  21. rumburake's Avatar
    Same problem here. After fail, phone also becomes hot and battery starts draining fast unless you reboot.
    Seems impossible to be a hardware issue - has to be firmware - so why does it need service at Samsung?
    01-20-2015 07:36 AM
  22. capk69's Avatar
    Has to be a 4.4.2 issue, as screen mirroring will no longer work on my Sprint Samsung Galaxy G3 and my Samsung Smartv. Everything else works - YouTube, media files form my G3 to my Sammy TV works perfectly. Just no more screen mirroring.
    <Frustrated>
    02-07-2015 04:20 PM
  23. mcambron's Avatar
    Any update on this? I have the same issue and just spent the day trying a soft reset and reinstalling all of my accounts. No Luck.
    03-29-2015 12:03 PM
  24. johnnybb20001's Avatar
    Exactly the same - Chromecast doesn't give you the same Mirror and the Samsung screen mirror did in the past. Bloody annoyed - Mirror was the reason I bought a Samsung phone and SS Smart TV!
    RUBBISH
    04-07-2015 06:19 PM
  25. Anjani Kumari's Avatar
    I too have same issue... but wen I talked to the support team they said they can't do anything. ...I will have to wait for the till a fix or the next upgrade is released
    04-21-2015 05:06 AM
34 12
  1. Is there no 'Manual' button in 4S email setup?
    By John66NY in forum Samsung Galaxy S4
    Last Post: 02-22-2015, 01:20 PM
  2. How do I stop the month view in Google Calendar?
    By Paul Butt1 in forum Samsung Galaxy S5
    Last Post: 12-03-2014, 07:49 AM
  3. Virgin Mobile S3 Need to update to latest Kit Kat
    By Michelle Downes in forum Samsung Galaxy S3
    Last Post: 12-02-2014, 11:38 AM
  4. Moving Apps to SD Card
    By rayf01 in forum General Help and How To
    Last Post: 12-01-2014, 02:07 PM
  5. where's my droid
    By tennislvr8 in forum Android Apps
    Last Post: 12-01-2014, 11:11 AM
