1. MileHiMo303's Avatar
    Thinking bout buying a Galaxy Note 4 without a contract and using it on a Pay as you Go program rather than getting stuck on a 2 year contract. HELP!!
    12-01-2014 11:39 AM
  2. VW Maverick's Avatar
    Welcome.
    That may be a better question for either a Metro PCS or Cricket location.
    Every situation, phone and carrier are different.
    Mav.
    12-01-2014 01:09 PM
  3. MileHiMo303's Avatar
    Ok Ill try..Thank you
    12-01-2014 01:52 PM
  4. VW Maverick's Avatar
    No prob.
    I did not want to give any wrong info.
    I am thinking it is possible, but am not sure.
    Mav.
    12-01-2014 02:09 PM
  5. Rukbat's Avatar
    Different models work on different frequencies - "unlocked" only means that it won't reject a SIM card from another carrier, it doesn't add frequencies.
    Cricket uses AT&T towers, so if you buy an unlocked (or locked, most likely) AT&T Note 4 it will work on Cricket.
    MetroPCS uses TMobil towers, so if you want to use MetroPCS, get a TMobil Note 4.
    If you're using the wrong phone, you'll get voice and text, but depending on where you are you might get very slow data.
    VW Maverick likes this.
    12-01-2014 02:18 PM
  6. Raymond Magana's Avatar
    Which carrier can a sprint note 4 SM-N910P work on. I was trying to go to cricket
    05-11-2016 02:58 PM
  7. Rukbat's Avatar
    Sprint only activates Sprint phones. It's their method of "locking" the phone.
    05-13-2016 12:38 PM
  1. its December still no OTA lollipop?
    By dan smartt in forum Google Nexus 7 Tablet (2013)
    Last Post: 12-10-2014, 10:14 PM
  2. Reboot when pressing power button on Lollipop
    By tongrhj in forum Google Nexus 4
    Last Post: 12-09-2014, 11:07 PM
  3. How do I stop the month view in Google Calendar?
    By Paul Butt1 in forum Samsung Galaxy S5
    Last Post: 12-03-2014, 07:49 AM
  4. Workaround for using Adobe Flashplayer on Nexus 7?
    By supersadie in forum Ask a Question
    Last Post: 12-02-2014, 12:47 AM
  5. Replies: 1
    Last Post: 12-01-2014, 12:29 PM
