1. AlekikaHawaii's Avatar
    Hello, I'm having some problems with my android. I own an Alcatel One Touch Fierce, Jellybean 4.2.2. Some of the problems include:
    - I am not able to download pictures from the internet or music from an app
    - When I go to my File Manager and try to delete some stuff from my SD card, it say "No permission to delete"
    - When I move an application to my SD card and try to move it back later it either says "Failed to move application" or "Failed to move application. The application does not exist."
    I feel like it has something to do with the SD card but I'm not sure. Help?
    12-06-2014 11:25 AM
  2. Cool Dolan's Avatar
    Well,if you want to delete,or move something important you need to root your device !
    And if you are unable to download pictures or music,check your memory!
    Hope this will help!
    12-06-2014 05:10 PM
  3. Rukbat's Avatar
    Put the card into a card reader, plug it into your computer and try to copy a file to it. Jellybean had no restrictions on the SD card.
    12-06-2014 06:05 PM
  1. Command Center Works With Third Party Launchers
    By KPMcClave in forum Motorola Droid Turbo
    Last Post: 12-08-2014, 02:35 PM
  2. Xperia SP multitouch problem?
    By LoizosAristides in forum Ask a Question
    Last Post: 12-06-2014, 05:06 PM
  3. HTC Droid DNA update problem
    By Ateeq Imran in forum Ask a Question
    Last Post: 12-06-2014, 01:13 PM
  4. Why won't my Note 3 on 4.3 permanently delete videos from the SD card?
    By Boogaloo Stu in forum General Help and How To
    Last Post: 12-06-2014, 11:57 AM
  5. Nexus 9 or Samsung Gallaxy S 10.5, which to replace laptop?
    By homeinhevn1 in forum Ask a Question
    Last Post: 12-06-2014, 11:54 AM
