Best android browser with less battery consumption
Issac Johnson
24
Chrome taking to much battery, I need a browser that's fast, secure and less battery usage. Android 5.0...
There are about a dozen on the Play Store. Download them, one at a time, and see which one suits you best. The one with the least battery consumption may be the one you like least.
Two options for a browser that uses less battery than others. The first is Opera Mini. That was is very lightweight and barely uses any battery. The trade-off is that it feels like a mobile browser and doesn't offer much of the functionality of the modern mobile browsers that can also serve as true desktop browsers. The other is Atlas. I have just started using it. So far, it can do everything the other browsers do and is less battery intensive. The key is finding a browser that does not reload or work in the background when it's not the main app on screen.
kiki2025
