1. rejectedpotato's Avatar
    So my phone has been draining very fast while sleeping. I decided to turn WiFi off and it seemed to stop draining so fast. I would prefer leaving WiFi on. How would I fix this?
    Galaxy S4 (SGH-1337M)
    12-09-2014 07:38 PM
  2. B. Diddy's Avatar
    Does wi-fi drain the battery during the day? What do the battery stats show? What app or service seems to be using the most battery during that period?
    Have you considered just keeping the phone plugged in overnight?
    12-10-2014 01:03 AM
  3. rejectedpotato's Avatar
    Wi-Fi is keeping phone awake. I set WiFi so it would go off when sleeping but haven't tried it. As u can see when the WiFi is off my phone isn't awake.
    Attached Thumbnails WiFi draining battery-screenshot_2014-12-10-10-47-53.jpg   WiFi draining battery-screenshot_2014-12-10-10-47-34.jpg
    12-10-2014 09:49 AM
  4. rejectedpotato's Avatar
    Help pls
    12-25-2014 09:21 PM
  5. belodion's Avatar
    Something is waking your phone repeatedly. If you must leave wifi on overnight, make sure that Location Reporting is set to Battery Saving Mode....or Off if you don't want any reporting. Make sure that your Email and Accounts are set to sync at sensible intervals. Your Mobile signal looks bad....switch off at night, otherwise the phone may be searching for a signal and draining battery.
    You could consider installing an app such as Wakelock Detector, to find what is keeping your device awake at night.
    rejectedpotato likes this.
    12-26-2014 10:19 AM
  6. rejectedpotato's Avatar
    Ty. Will install wake lock detector. I have a few apps I suspect might be causing this.
    12-26-2014 08:35 PM
  7. Rukbat's Avatar
    See Wakelock Detector with non-rooted phone if the phone isn't rooted.
    belodion likes this.
    12-27-2014 12:38 AM
  8. rejectedpotato's Avatar
    I will have to do that tutorial tmrw but this is the kernel wakelock.
    Attached Thumbnails WiFi draining battery-screenshot_2014-12-27-23-12-33.jpg
    12-27-2014 10:14 PM
  9. Rukbat's Avatar
    Main and Power Manager seem to be keeping the phone awake most of the time. No idea what those are, though.
    12-28-2014 01:41 PM
  1. Replies: 6
    Last Post: 09-22-2015, 08:43 AM
  2. battery life after lollipop
    By Fuzzy761210 in forum Moto X (2014)
    Last Post: 07-13-2015, 06:07 PM
  3. My Note 4 freezes causing me to do battery pulls.
    By Coconut8469 in forum Samsung Galaxy Note 4
    Last Post: 12-11-2014, 12:46 PM
  4. WiFi Text?
    By Chrisqo in forum Android 4.4 KitKat
    Last Post: 12-09-2014, 05:02 PM
