07-09-2015 11:09 AM
33 12
tools
  1. Kyle Lemieux's Avatar
    Here are my device details:
    Android version: 4.4.2
    Baseband version: M8610B-AAAANAZM-1.0.6038
    Kernal version: 3.4.0+
    Build number: KOT49I.MS32310c
    Software version: MS32310c
    I tried to do it with TW, even by changing the modstrings, but I still got "This phone isn't currently supported" D:
    Ginger Anderson likes this.
    12-10-2014 06:45 PM
  2. Golfdriver97's Avatar
    Welcome to the forums. The kernel build date is probably newer than June 2. You can look up the Unlockr. They usually have some pretty good root guides. But if no one has found a way to root it, there won't be a way to.
    Kyle Lemieux likes this.
    12-10-2014 10:29 PM
  3. Rondeau7's Avatar
    Kyle Lemieux I recently bought the same phone with the same build and software version (c). The easiest way to root this phone is to downgrade back to the (b) version through LG support tools and flash the proper kdz file with adb. I did that and then the towelroot apk worked on this phone. After that install SuperSu and the required binaries. Then check your root status and it should be good to go. If the phone gets an OTA update just ignore it. If you install the update it will go back to the (c) version and unroot the phone. LG has gone to great lengths to make sure this phone is well secured from hacking. PM me for more information if you need it. I just did this a few weeks ago and already have unlocked the bootloader and have CWM custom recovery on the phone. I've flashed a different kernel on it. Just need to buy a bigger external sdcard for flashing ROMs.
    P.S In order to get developer options available you need to got to Settings>About Phone>Software Info>Build number>tap it 7 times to unlock that feature. Another security update that LG made. Oh and make sure to check allow downloads from other sources too.
    12-11-2014 08:00 PM
  4. Kyle Lemieux's Avatar
    First of all, id like to thank you for replying. But, do you think you can make a step-by-step guide on what to do? I dont wanna mess up and brick my phone lol
    12-13-2014 09:15 PM
  5. Sagbag25's Avatar
    I'm having the same problem, same build as well. A guide would be nice
    F Montes likes this.
    12-14-2014 05:45 PM
  6. Luis Linares1's Avatar
    I have the same phone please teach me how to downgrade
    12-17-2014 12:28 PM
  7. livelifeCA's Avatar
    Same problem same Firmware, why doesnt Towelroot or Stump work, Devs dont update Crap.. not Even a Downgrade Guide i have the LG Flash tool
    12-17-2014 05:54 PM
  8. F Montes's Avatar
    How do we get ms32310b kdz file. Step by step instructions on downgrading would really help. Thank you.
    12-17-2014 09:26 PM
  9. Rukbat's Avatar
    Check the L70 forum on XDA regularly to see if someone's found an exploit to use to root the phone on 4.4.2.
    12-18-2014 12:51 AM
  10. Luis Linares1's Avatar
    Really want to root and no progress yet
    12-18-2014 07:34 AM
  11. livelifeCA's Avatar
    Nothing here yet i tried Downgrading but i got an error Previous something, All my Devices are Rooted except for this Baby. Someone Tutorial step by Step with Links come on, XDA says Towelroot.
    12-18-2014 10:02 AM
  12. livelifeCA's Avatar
    How to Downgrade is here but Do NOT Download Latest LG Flash tool From Dev Host website my AVG said its a Virus 100%
    12-18-2014 10:10 AM
  13. livelifeCA's Avatar
    Cant Post Links cause im NEW Garbage im trying to be Helpful here Admins what kind of Ish is that
    12-18-2014 10:13 AM
  14. Rukbat's Avatar
    To prevent people from making one-post advertising threads. Ten posts to post a clickable link or, if the link is really helpful, mung it (put spaces around the dots). If someone really wants to go to the link, he'll copy, paste and delete the spaces.
    As for the OP, the exploit that Towel Root used to root was patched on kernels dated June 3, 2014 and later. Someone has to find a new exploit for newer versions/kernels/phones. That could take 10 minutes, 10 months or never. (Most people capable of reading the code don't have the time, patience or inclination to study hundreds of thousands of lines of code, looking for something that might be exploitable. It's a long-term, full-time job.)
    12-18-2014 03:42 PM
  15. Rondeau7's Avatar
    Do this at your own risk., I am only going to guide you on how to get this device rooted anything else you do to it afterwards is not my problem.
    1. Download and install LG Flash Tool 2014
    2. Download and extract MS32310b firmware
    3. Power on phone and go to settings>general>about phone>software information>build number and tap it 7 times you are now a developer.
    4. Go to developer options and click on allow usb debugging.
    5. Connect usb cord to your phone and allow your computer to install the device drivers for your phone you might have to go through every option to get all of the phones information on your computer.
    6. Open up LG Flash Tool 2014 file make sure the MS32310b kdz is in that file folder just to make things are easier.
    7. Power off phone and plug in your usb cord while holding the vol + button to go into download mode.
    8. Open the LG Flash Tool application and make sure the download mode is in emergency mode, the type should be 3GQCT choose the correct kdz file and press normal flash, it will bring up another window and press start, this will bring up another window and click ok.
    9. If everything goes well then the LG Flash Tool should flash the MS32310b software on your phone. follow any directions this program asks.
    10. If successfull then you have the previous software on your phone
    11. Go through all of the initial startup processes and then download the Towelroot apk from the internet and install it via file manager (follow all instructions and just choose o.k to the download and installation as warnings will come up ignore them.)
    12. Open the Towelrooot app and press make it rain you should then be rooted.
    13.. Install SuperSU and update binaries normally, check if you have root with root checker.
    This is as far as I'm going to go with this phone, I've bricked a couple of them by unlocking the bootloader, after that your only choice is fastboot. I'm going back to my LG f6 because it is alot easier.
    JMZ360 likes this.
    12-18-2014 06:26 PM
  16. livelifeCA's Avatar
    Yes there making it harder to Root now i cant Risk it could lose my # details.. is this for Metro
    12-18-2014 06:41 PM
  17. Luis Linares1's Avatar
    All the exploits i find are all from June or July and no longer work. These include Towelroot Framaroot Kingo and stumproot. Too bad i guess ive been searching for the past 3 days. Ill just have to wait. ๐Ÿ˜“๐Ÿ˜๐Ÿ˜ข
    12-18-2014 07:24 PM
  18. Luis Linares1's Avatar
    Yes it is for metro i have them
    12-18-2014 09:04 PM
  19. Luis Linares1's Avatar
    Anymore news about this devices root? Plz i want it SO bad!
    12-20-2014 09:34 PM
  20. Rukbat's Avatar
    Most devs are probably working on 5 or 5.0.1, or are waiting for 5.0.2. It's going to be a while. I don't mean a few days, I mean maybe 6 months or so. Finding an exploit to use to root isn't something simple, like brain surgery. It's more like brain surgery on an alien on a planet we haven't discovered yet - done remotely.
    12-20-2014 10:11 PM
  21. jjrc's Avatar
    where i can find ms32310b firmware?
    Ted Bradford likes this.
    01-05-2015 10:15 PM
  22. Ted Bradford's Avatar
    Good question. I have been looking for a site were i can DL that too. I want to root my LG L70 and since i very recently updated my phone to the ms32310c none of the programs listed above will work. So i need to downgrade to B. I've been looking for a couple of days now and the only one i found was on YouTube with a link. but it was for a duel sim phone and i have a single sim. so if anyone knows of a good DL site for the MS32310B please leave link to site.. Also i am new to this site i just signed up about 10 min ago.. again thanks to anyone who can help..
    UPDATE... found site for file... but won't let me submit links since i'm a new member.. but i'll try..
    .lg-phones.org/official-stock-lg-l70-firmware-rom
    .html
    JMZ360 and Ally Ronk like this.
    01-15-2015 03:59 AM
  23. somerandomguy3's Avatar
    Can you help me out please
    01-27-2015 06:58 PM
  24. somerandomguy4's Avatar
    Help me please
    01-27-2015 07:05 PM
  25. JMZ360's Avatar
    Thanks a bunch Rondeau7!
    Rondeau7 likes this.
    02-14-2015 07:01 PM
33 12
  1. Replies: 45
    Last Post: 07-28-2015, 04:03 PM
  2. Replies: 3
    Last Post: 12-11-2014, 09:31 AM
  3. How to limit # of screen on Xperia Ion
    By oncinc in forum Sony Xperia Series
    Last Post: 12-11-2014, 01:56 AM
  4. Why is my Samsung S3 not charging like it used to?
    By NH1 in forum Samsung Galaxy S3
    Last Post: 12-10-2014, 11:59 PM
  5. phone is HOT and battery is junk
    By wetermommy in forum AT&T Samsung Galaxy S4
    Last Post: 12-10-2014, 06:44 PM
