1. ariola muhametaj's Avatar
    Please can somebody explain something. I have updated since 3 days to lolipop 5.0.1 and i charge my nexus 5 2-3/times a day. What is going on? I dont use internet 3g,i dont listen music. I only use viber,textra and phone calls. Thank you.
    12-19-2014 07:39 PM
  2. ariola muhametaj's Avatar
    Look
    12-19-2014 07:40 PM
  3. Rukbat's Avatar
    For one thing, you have your Exchange email app running constantly. It should be set to Push updates (the server wakes the app when there's email for it) or manual updates (it updates when you open the app), not constant polling, which kills the battery quickly.
    For another, if you keep using the battery down to near 0% 2-3 times a day, you'll be replacing the battery every 4-6 months. Charge when it's down to no less than 40% (and let it charge to 100%). The battery doesn't care whether that's convenient for you or not. Constantly discharging a battery almost all the way will give you about 300 charges before the battery fails. Charging it at 40% should give you about 1200-1500 charges.
    12-20-2014 12:29 AM
  4. ariola muhametaj's Avatar
    I still dont know what to do. Look at this . i did what you told me and i dont know what to do anymore.
    12-20-2014 08:12 AM
  5. Golfdriver97's Avatar
    I would try clearing the system cache in recovery. [GUIDE] Nexus 5 Recovery
    12-20-2014 08:33 AM
  6. Rukbat's Avatar
    Then open whatever app you're using for your Exchange email, look in Settings for the refresh interval and set it to automatic or push or off. Fully charge the battery, then run it a few hours and see if Exchange Services is still using most of the power being used. (If it is, get rid of that app and get one that was written by someone who knows how to write apps. An email app should be one of the lowest power users in the phone that's not hibernated. [A hibernated app won't use any power unless you manually run it.])
    12-20-2014 03:43 PM
  7. nycspaces.'s Avatar
    N5 on 5.1 with exchange is a disaster...probably why it has not really rolled out...5.2 on N7 seems better. However if Android is going to make a play for corporate they need to get this straightened out - with push mail.
    02-14-2015 01:59 PM
  1. Are there any phones with the Japanese calendar?
    By Rikku Watro in forum Ask a Question
    Last Post: 12-24-2014, 08:41 AM
  2. Replies: 6
    Last Post: 12-24-2014, 02:08 AM
  3. Replies: 4
    Last Post: 12-22-2014, 04:32 PM
  4. 5.0.2 update on the way???
    By radgatt in forum Google Nexus 6
    Last Post: 12-20-2014, 04:12 PM
  5. Replies: 10
    Last Post: 12-19-2014, 11:24 PM
