1. technowiz11's Avatar
    My phone battery charges and shows a blank screen with no charging animation but when I try to turn it on, the camera area gets hot and the computer recognises it but its still shows a blank screen.
    12-20-2014 10:16 PM
  2. dancing-bass's Avatar
    what kind of phone, and what version of Android is it running? give us as much information as possible, what the problem isand exactly what is happening.
    If you're charging your device when it's turned off, most phones will keep the screen off. If you tap the power button, most phones will light up the screen with a charging animation (and some will show the battery percent level) for a few seconds before turning back on.
    Are you saying if you tap the power button the screen stays off but the device gets hot? is the device hot BEFORE you tap the power button?
    Have you tried charging with the device on? Does the same thing happen? What about unplugging before turning it on?
    12-20-2014 11:02 PM
  3. technowiz11's Avatar
    Hi, Its a Samsung Galaxy Mega running 4.2.2 STOCK. It doesn't show anything when i tap the power button, no charging animation whatsoever. The device doesn't turn on. When i tap the power button to try turn it on, it is just a blank screen but the camera area gets hot.
    12-20-2014 11:17 PM
  1. So, the police are being hunted now....sigh....
    By JnEricsonx in forum Politics
    Last Post: 01-27-2015, 06:51 PM
  2. Does the Note Edge really have Gorilla Glass?
    By EsEllEmm in forum Samsung Galaxy Note Edge
    Last Post: 12-31-2014, 06:28 PM
  3. Replies: 4
    Last Post: 12-28-2014, 05:52 PM
  4. T-mobile cancellation doesn't seem right....
    By rdalcanto in forum Google Nexus 6
    Last Post: 12-21-2014, 11:17 PM
  5. Replies: 1
    Last Post: 12-20-2014, 09:47 PM
