1. kates8600's Avatar
    Hi I'm interested in the above two devices.
    All I really want it for is to monitor my steps, track my sleep & be able to use it as a silent alarm. I often miss phone calls so it would be good to let me know when my phone is going off.
    My other half uses the Fitbit Flex but the vibration on the silent alarm doesn't go on long enough, nor is it strong enough to wake me up. I'm assuming this would be the same with the Fitbit charge etc.
    I'm quite a deep sleeper and easily sleep through my house phone ringing when its on my bedroom side.
    So will the Gear 2 Neo or Gear Fit be suitable & have a strong enough vibration to do what I'm looking for? Is there any other device I should be looking at?
    Thanks in advance ^_^
    01-02-2015 12:10 PM
  2. hokie_prof's Avatar
    I have the Gear Fit. I don't use it as an alarm to wake me. I actually have it set so that it won't give me any alerts when I sleep.
    There is an app called Sleep Genius that is suppose to help you manage your sleeping pattern. It works on the Fit, but I haven't tried it yet. I think it has a gradual waking feature. Maybe that's worth a try?
    As a heavy sleeper, it seems like you might eventually learn to sleep through anything... I will say that when I'm working and I'm deep in thought, the vibration sometimes makes me jump. I have found that the watch definitely keeps me from missing calls during the day. I may not hear the ring, but I don't miss that vibration.
    I hope that was helpful in some way...
    01-10-2015 04:53 PM
  1. My Samsung tab 3 t311 is not compatible with many apps?
    By amitosh navy in forum Ask a Question
    Last Post: 12-22-2015, 11:32 AM
  2. Samsung Galaxy Note Pro 12.2
    By eds817 in forum Marketplace Archive
    Last Post: 01-08-2015, 10:12 AM
  3. Why won't my Samsung Galaxy Note 1 phone start?
    By greenak in forum Ask a Question
    Last Post: 01-07-2015, 11:56 AM
  4. Replies: 2
    Last Post: 01-03-2015, 01:05 AM
  5. Vudu movies on Samsung Tab S?
    By Dryasanne in forum Ask a Question
    Last Post: 01-02-2015, 09:06 AM
