1. elvise's Avatar
    Have a nexus 5, running lollipop 5.0.1 At first it was fine, but then my battery started draining faster than Sarah Palin's appeal. Now I can only get through the day with the battery saver on, and even so it just limps through the day with little usage. I've reset it a few times to no avail. Please help, I love lollipop, there must be a fix out there that I haven't found searching the forums. Thanks, if you can help, I will name my phone after you . . .
    Update: in my desperation I came across this thread:
    search (I am not yet allowed to post links) Issue 79567: Battery draining fast on Nexus 5 after installing 5.0
    These are real people with the same problem, not poser iphone fanboys or malicious whiners, and it seems there is no real information out there regarding this problem. Help me SOME--bodee
    01-03-2015 06:07 AM
  2. Golfdriver97's Avatar
    Even though the resets should have taken care of this, but try a cache clear in recovery: [GUIDE] Nexus 5 Recovery
    01-03-2015 09:21 AM
  3. elvise's Avatar
    Sorry, I neglected to mention I did this already . . . but thanks for responding
    01-03-2015 09:38 AM
  4. belodion's Avatar
    At the end of a day's use, before you recharge, what do your battery stats reveal as the main users of charge?
    01-03-2015 12:31 PM
  5. Rukbat's Avatar
    I notice a lot of people having the problem, but not a single response from Google. Maybe the last 2 paragraphs of [Battery Drain] [Lollipop] [LRX21O] - UPDATED 19-NOV-2014 - Post #3 - XDA Forums are true.
    01-03-2015 04:27 PM
  6. elvise's Avatar
    Ok, here's another update: last night I reset it, then charged it. Before I went to bed I turned off all my gmail syncs. This morning it is at 69%. Battery shows cell standby 22%, Android system 3%, google play services 2%, Android OS 2% and screen 1%. It appears turning off gmail sync saved a little battery, but still, 69% overnight with nothing running? Yikes!
    01-03-2015 08:35 PM
  1. Any news about the Lollipop update for M8?
    By Deathunter-M8 in forum HTC One M8
    Last Post: 02-11-2015, 01:47 AM
  2. Foxfi on lollipop
    By Umass021 in forum Samsung Galaxy S5
    Last Post: 01-12-2015, 08:16 AM
  3. Why is my battery draining so fast?
    By Mohammed Abib in forum Samsung Galaxy Note 4
    Last Post: 01-08-2015, 07:29 AM
  4. Replies: 0
    Last Post: 01-03-2015, 03:53 AM
  5. Why doesn't the camera on my Z998 cell phone work?
    By Danielle Barnes1 in forum Ask a Question
    Last Post: 01-03-2015, 12:10 AM
