1. Tristan Struiyck's Avatar
    So i got this issue with my wifi its like when i connect to my home wifi and like turn my mobile on sleepmode(lockscreen) and then after a couple of minutes i want to browse internet or play some internet required apps but cant because there is no interter,However on top of the screen i just see the wifi bars full and the mobile is connected to internet.
    This problem is only with my home internet and only with my mobile.
    01-09-2015 03:09 PM
  2. srkmagnus's Avatar
    Do you have an active Wi-Fi connection? I would suggest reseting the router and see if that helps. If it's connected to the internet, then the games or web browsing should work despite Mobile Data being disabled.
    01-09-2015 03:20 PM
  3. justchris20's Avatar
    Have you a second phone with the same mac id? This happens if you use a custom rom for example.
    01-09-2015 03:39 PM
  4. Tristan Struiyck's Avatar
    Mmh iam not sure if it have same mac id as an other device i should check this,and as for the mobile data its on
    01-09-2015 03:43 PM
  5. Tristan Struiyck's Avatar
    Nope the mad id is not the same as other devices
    01-09-2015 03:44 PM
  1. Why is my Droid Turbo prompting me to turn on the location everytime?
    By mjordan68x in forum Motorola Droid Turbo
    Last Post: 01-20-2015, 03:56 PM
  2. Replies: 2
    Last Post: 01-10-2015, 03:35 AM
  3. How do I make video calls on my LG G3?
    By JaymesPayten in forum Ask a Question
    Last Post: 01-09-2015, 03:18 PM
  4. Screen shuts off after 15 seconds
    By Meralee Crowl in forum Samsung Galaxy S5
    Last Post: 01-09-2015, 02:43 PM
  5. Why isn't my Galaxy S5 microphone connecting to Google?
    By Monica Fontaine in forum Samsung Galaxy S5
    Last Post: 01-09-2015, 02:34 PM
