1. drenco's Avatar
    Hi i rebooted my stock Note 3 the other day and once rebooted a message keeps flashing up every 3 seconds 'unfortunately the process android.process.acore has stopped' you can press OK then it appears again 3 seconds later, upon investigation it seems its a problem with the Contacts & Contacts Storage which you have to clear the data disable enable etc but my phone still got this message popping up making it virtually unusable, Please HELP ? ive read through other threads i could find and i really dont want to do the last resort of a Factory reset etc, thx
    PS: Ok what does this mean ive just booted into Safe mode for the first time and the phones been on for 30 minutes without this message keep popping up usually it pops up in 5 mins after reboot.
    01-09-2015 05:26 PM
  2. belodion's Avatar
    Welcome to the forums.
    It suggests that a third-party app, now temporarily disabled because you have entered Safe Mode, may have been interfering with the normal functioning of your Contacts and/or Contacts Storage apps.
    01-09-2015 05:42 PM
  3. drenco's Avatar
    So whats the best way to track down this offending app as i have many new apps installed all of the time.
    01-09-2015 05:49 PM
  1. Replies: 2
    Last Post: 03-09-2015, 10:10 AM
  2. how are the leather backs holding up?
    By goldkear in forum Moto X (2014)
    Last Post: 01-11-2015, 05:37 AM
  3. Newest version of Gallery has media server capability (?)
    By Raymond Elliott in forum HTC One M8
    Last Post: 01-09-2015, 09:03 PM
  4. Why does the flash comes on?
    By iloz in forum Ask a Question
    Last Post: 01-09-2015, 06:42 PM
  5. Nexus 5 battery issues....HELP!?!?!
    By amanalki in forum Ask a Question
    Last Post: 01-09-2015, 05:36 PM
