1. Stein39's Avatar
    My average SoT is 2.5hrs in 6hrs with 13% remaining and my screen eats up 53% of the battery with 30% brightness. Android system and os eats up 20%. I've done everything i know to prolong my battery but the best sot i can achieve is 3.5hrs.
    Attached Thumbnails Why is my Note 4(Sm-N910c) battery so terrible?-1.jpg   Why is my Note 4(Sm-N910c) battery so terrible?-2.jpg   Why is my Note 4(Sm-N910c) battery so terrible?-3.jpg
    01-09-2015 07:25 PM
  2. Golfdriver97's Avatar
    Welcome to the forums. Can you upload a picture of your battery stats, please?
    01-09-2015 09:54 PM
  3. Salidmora's Avatar
    Hi,
    I got my phone 5 days ago. The first 2 times that I charged it, it ended around 2 and a half hours.
    But in other times, it last around 7 or 8 hours. With fast charging mode disabled all these times of charging.
    Isn't that high?
    Do you happen to know anything about this?
    04-26-2015 05:13 PM
  4. Golfdriver97's Avatar
    Hi,
    Isn't that high?
    If you were in a weak cell area, this might happen. The device will kill itself holding on to a faint signal.
    04-26-2015 07:18 PM
  5. Salidmora's Avatar
    excuse my English.
    I meant the charging time. From the moment that I plug in the charger to the moment that the 100% notification pops up, lasts 7 hours. Is that normal with using OEM and the fast charging mode disabled?
    04-27-2015 12:49 AM
  6. Golfdriver97's Avatar
    excuse my English.
    That does seem quite long. I would consider getting a different charger.
    From an AOSP M8
    04-27-2015 07:25 AM
  1. Something to check if adaptive fast charging is not working
    By EsEllEmm in forum Samsung Galaxy Note Edge
    Last Post: 10-18-2015, 01:39 AM
  2. Can i use my iPhone Charger 5v-1A to charge samsung S4 5v-2A ,PLZ?
    By ibrahim alfakharany in forum Batteries
    Last Post: 01-19-2015, 02:16 AM
  3. What is the new pro Google maps I'm seeing?
    By jordo487 in forum Samsung Galaxy Note 4
    Last Post: 01-10-2015, 07:34 PM
  4. Replies: 2
    Last Post: 01-09-2015, 08:37 PM
  5. Thule note 4 case
    By yeppie in forum Samsung Galaxy Note 4
    Last Post: 01-09-2015, 06:30 PM
