1. jaedre's Avatar
    I got my note 4 on Wednesday and it's battery would drain pretty quick when I'm using the phone, I would lose 5% in 10 minutes. The first picture confuses me with how much I have time left on battery. Please help me.
    Attached Thumbnails Note 4. Battery-1420909628672.jpg   Note 4. Battery-1420909641618.jpg
    01-10-2015 11:09 AM
  2. MaLik Hadi's Avatar
    i think it may be the time used and your graph does not tell anything post another when you reach below 30% battery.
    Posted via note 3
    01-10-2015 11:50 AM
  3. Rukbat's Avatar
    The graph says you have 99% of the charge left (the line above the one you circled). Of the 1% of charge used, Android system used 26% of that (or 0.026% of the total battery charge), the screen used 15%, etc. The total, if all apps using any battery were listed, and the numbers went to about 3 decimal places, would always add up to about 99.99% - which means that all the power used from the battery was used. In your case, that's 1% of the total capacity. (The percentages for the apps aren't percent of battery capacity, they're percent of total power use.)
    I don't know where you're getting that 5% loss number - the phone hasn't used 5% of the battery capacity yet.
    Malik, other than when conditioning the battery, you should never let the battery get below 40%. 50% is the ideal charge point for maximum battery life. Constantly draining the battery to 30% kills the battery more than twice as fast as charging it at 50%.
    01-10-2015 06:07 PM
  4. MaLik Hadi's Avatar
    if this is true then i have to charge times in a single day...cause i lose couole of percentages in a single minute on my note 3 may be my battery life is tottaly finished
    01-11-2015 12:53 AM
  5. Rukbat's Avatar
    My Note 3, in normal use, lasts over 8 hours to 40%. If I have to use it heavily and there's no power nearby to charge it, I have a spare, fully charged, battery in a soft plastic case in my pocket to switch with. (If I needed still more power, 2 more batteries and a charger are about $25.) That's one reason I won't buy a phone that doesn't have a field-replaceable battery. My 10 year old V551 spare phone is still on its original batteries. I want the original batteries to be working at near new capacity when the phone is so old that it can only be used to make sure I can get and make phone calls while my main phone is being repaired. (The battery in my Motorola Micro TAC only holds about 25% capacity now, but it's NiCd - and it's 26 years old.)
    If you lose more than a couple of percent an hour when the phone isn't doing anything, it's time to spend $10 on a new one.
    01-11-2015 02:48 PM
  1. Note 4 system update
    By doxilover in forum Samsung Galaxy Note 4
    Last Post: 01-11-2015, 09:13 PM
  2. Replies: 10
    Last Post: 01-11-2015, 07:47 PM
  3. Where do I find a guide to fully utilize Note 4?
    By Wayne Scott2 in forum Samsung Galaxy Note 4
    Last Post: 01-10-2015, 06:12 PM
  4. Google keyboard galaxy note 4?
    By WilliamLundstrom in forum Samsung Galaxy Note 4
    Last Post: 01-10-2015, 11:17 AM
  5. S note template text
    By Kianski in forum Samsung Galaxy Note 8.0
    Last Post: 01-10-2015, 10:39 AM
