1. AC Question's Avatar
    It is a sony xperia device
    01-17-2015 11:06 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! That can indicate a failing battery. Which Xperia do you have? Is it possible to replace the battery easily? That would be the first thing to try.
    It might also be due to something that is working overtime and using up battery too quickly. This can happen with poor cell signal or with a malfunctioning app. It would help to see some battery stats. Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    http://forums.androidcentral.com/amb...d-central.html
    01-18-2015 12:39 AM
  1. Replies: 12
    Last Post: 03-24-2017, 07:56 PM
  2. Why wont my AT&t S3 update to the new CWM?
    Last Post: 01-17-2015, 11:30 PM
  3. Replies: 1
    Last Post: 01-17-2015, 11:16 PM
  4. Replies: 1
    Last Post: 01-17-2015, 10:59 PM
  5. Does my phone have a rootkit?
    Last Post: 01-17-2015, 10:06 PM
