1. AC Question's Avatar
    I have an original nexus 7 that was upgraded to lollipop and ran very very slow. I cleared caches etc and this improved things slightly so I decided to perform a factory reset.
    After the factory reset the installation screen stopped at the wifi screen and I could not go past this without getting a wifi connection. The nexus 7 would not make a connection to my ASUS AC-68u router on my normal network. This network is protected with a long password (21 chars) so I enabled my guest network with a simple password and this seemed to work, at least got me past the configuration screen.
    After this I could not get a reliable wifi connection for more than 5 seconds so I gave up and flashed back to 4.4.4.. This works fine.
    When 5.0.2 came out I performed a manual upgrade and ran into exactly the same issue as before.. I reset my router back to factory defaults, and reconfigured it manually again then tried again.. Now I can not even get a connection to the guest network.
    Is this just something I am doing, some issue with my wifi router, or something else??
    I am baffled and would appreciate some help.
    Thanks.
    01-18-2015 05:11 PM
  2. Ichi_Bear's Avatar
    Lollipop has issues with the original Nexus 7. I have the Nexus 7 2013 and the initial Lollipop update was no problem. If I were you I would go back to KitKat on your tablet 😒
    01-18-2015 05:14 PM
  1. Replies: 1
    Last Post: 01-18-2015, 06:32 PM
  2. Replies: 1
    Last Post: 01-18-2015, 05:34 PM
  3. Why do my text message switch to MMS when I use an emoticon?
    By NafcMontana in forum Ask a Question
    Last Post: 01-18-2015, 05:05 PM
  4. How do I transfer music?
    By mac300010 in forum General Help and How To
    Last Post: 01-18-2015, 04:56 PM
  5. VZW/GS4: How can I tell why my phone is logging dumps?
    By BillDennes in forum Verizon Samsung Galaxy S4
    Last Post: 01-18-2015, 04:55 PM
