1. AC Question's Avatar
    hi my phone died yesterday with 45% battery on it
    and when i put it on change the google sign just flashing on and off tried the power and up or down volume keys nothing is working
    01-19-2015 07:12 AM
  2. belodion's Avatar
    If you feel competent to do it without doing damage, remove the back and take a look at the battery. If it's bulging, that's a sure sign of failure, but even if undistorted, it may be bad. If it is bad, you can replace it yourself with some difficulty, for which there are online guides.
    01-19-2015 07:30 AM
  1. Nexus 7 battery rapidly drains after Lollipop install
    By ImAnAngryBeaver in forum Google Nexus 7 Tablet (2012)
    Last Post: 02-21-2015, 09:45 PM
  2. Replies: 1
    Last Post: 01-19-2015, 05:23 PM
  3. How do I get my calander to do a view of things for the week?
    Last Post: 01-19-2015, 07:38 AM
  4. Replies: 1
    Last Post: 01-19-2015, 07:33 AM
  5. Replies: 0
    Last Post: 01-19-2015, 06:06 AM
