My Nexus 7 is just 13 months old and the battery will no longer charge, time to replace the battery?
A
AC Question
My nexus 7 is just 13 months old and the battery will no longer charge.
Is there any kind of warranty that I can claim?
Or is there anyway of replacing the battery?
Thanks
belodion
Co-Ambassador Team Lead
Moderator
Jun 10, 2014
39,388
253
83
Re: My nexus 7 is just 13 months old and the battery will no longer charge.
I don't think that the warranty would cover battery failure after 13mo.
Yes, you can buy replacement batteries, together with the simple tools you'll need if you intend to do it yourself.
However, are you sure it's the battery at fault, and not the charger, USB lead, USB port, or something else?
Nikoczzzz
