When I hold the power button on Sony xperia z3v it plays the notification sound. Is there a way to disable this?
If you are referring to the sound the phone makes when powering on, try going to settings, sound, and uncheck startup sound.When I hold the power button on Sony xperia z3v it plays the notification sound. Is there a way to disable this?
Hi
Did anyone get a fix for this I am currently having the same issue with a Galaxy S5. if you turn notifications to mute then this removes the sound but then you get no message notifications.
