My phone keeps making USB Connect / Disconnect noise when plugged into PC, why?
A
AC Question
Phone keeps making USB Connect / Disconnect noise when plugged into PC
Just recently my phone started making the USB connection sounds when plugging into my PC, but it's making the sound over and over again which is obviously really annoying. Every 10-20 seconds, totally random it makes the connect noise, then sometimes the disconnect USB noise. Is this a hardware issue or possibly a problem when software/firmware was updated? My phone is totally stock.
Galaxy S3
Android version 4.2.2
Thanks.
Golfdriver97
Trusted Member Team Leader
Moderator
Dec 4, 2012
35,367
113
63
Re: Phone keeps making USB Connect / Disconnect noise when plugged into PC
Welcome to the forums. It's probably related to the hardware. Try a different cable. If it still makes the noise, then there is a bad connection in the phone itself.
bnutz
