1. AC Question's Avatar
    Just recently my phone started making the USB connection sounds when plugging into my PC, but it's making the sound over and over again which is obviously really annoying. Every 10-20 seconds, totally random it makes the connect noise, then sometimes the disconnect USB noise. Is this a hardware issue or possibly a problem when software/firmware was updated? My phone is totally stock.
    Galaxy S3
    Android version 4.2.2
    Thanks.
    01-21-2015 09:04 AM
  2. Golfdriver97's Avatar
    Welcome to the forums. It's probably related to the hardware. Try a different cable. If it still makes the noise, then there is a bad connection in the phone itself.
    01-21-2015 09:11 AM
  1. Replies: 2
    Last Post: 01-21-2015, 02:47 PM
  2. How can I unlock my phone if I forget the pin?
    Last Post: 01-21-2015, 01:55 PM
  3. Replies: 1
    Last Post: 01-21-2015, 11:04 AM
  4. When will the Tab 4 get Android 5?
    Last Post: 01-21-2015, 09:16 AM
  5. Replies: 1
    Last Post: 01-21-2015, 08:41 AM
