1. AC Question's Avatar
    I have bought a new android 4.4.2 KitKat mobile phone. It is QMobile Noir i7. Problem is that, I charge it to 100%. Then I start using it. I use internet, play games, call, text (all activities). But its battery display meter continues to show 99% or 100% (even almost after 6 or 7 hours). If I power off it, remove battery, put it again and then start it, then the battery meter shows actual battery level (like for example, 30% or 20%). If I don't do this, then it continues to show 99%, then suddenly alarms me low battery, when it remains only 15% (Or sometimes, it even don't do this and suddenly power off without any warning).
    Any solutions?
    01-24-2015 04:41 AM
  2. belodion's Avatar
    It's faulty, so you could return it. Alternatively, a Cache Partition wipe may help, or you could try installing a third-party battery metering app.
    01-24-2015 06:08 AM
  3. Fly Jie's Avatar
    I have the same problem, the battery in my ipod can not store power either. I do not what I should do.
    01-25-2015 07:54 PM
  4. English Billa's Avatar
    It Depend On Your Charger If YOur Phone Is Full Then Quickly Remvo The Charger ... And Then Check ..Same Time YOur Phone On Charging And YOu Dont Remvo it So Your Phone Bettrey Is Stuck There So U Can Remvo YOur Charger If Your Phone Is Full Now
    04-01-2015 11:56 AM
  1. Replies: 2
    Last Post: 06-03-2015, 12:39 AM
  2. Does the Android have a flash player or similar?
    Last Post: 01-24-2015, 03:12 AM
  3. Do games totally break the android phones?
    Last Post: 01-24-2015, 03:08 AM
  4. How to activate Pocket Data Network in Android 5.0.2 ?
    Last Post: 01-24-2015, 03:07 AM
  5. When will unlocked htc M7 gets its update to android 5.0?
    Last Post: 01-24-2015, 02:24 AM
